Thanks a lot. I actually tried changing the thermostat and my revised file is as per attached “graphene_thermal_conductivity.in” and also mentioned below. However, thermal conductivity value of graphene is found to be very small as compared to literature.
Temperature profile along Z direction is also very linear as per attached plot “Temp (K) Vs. Z(Ang)”. Also, attached is kinetic energy graph versus time (ps) as per file “Kinetic Energy Swapped versus time (ps)”, which also seems fine. In order to calculate thermal conductivity, I calculated slope of temperature profile as dT/dJ = 0.6293 K / Ang, while slope of Kinetic energy exchanged versus time is 11.11 eV / ps. Simulation box is orthogonal with dimensions = 50 x 50 x 100 (Ang x Ang x Ang) with 1008 C atoms. Hence, cross sectional area for heat flow along z direction is 50 x 50 = 2500 Ang^2.
Thus, using formula: Thermal conductivity k = (dJ/dt) / (Cross Section Area)(dT/dJ) = 11.11 eV/ps / (50*50) * 0.6293 K/Ang ~ 11.3 W/mK.
Please let me know what is error in my calculation.
Input Script:
atom_style full
#Atom definition
read_data graphene_1008atoms
#Creating Regions
region up block INF INF INF INF -5 5 units box
region down block INF INF INF INF -50 -40 units box
#Potentials
pair_style tersoff
pair_coeff * * SiC.tersoff C
mass 1 12
neighbor 2.0 bin
neigh_modify delay 5
dump snap all cfg 10000 dump.config.*.cfg id type xs ys zs vx vy vz
equilibrium
velocity all create 300 458127641 mom yes rot yes dist gaussian
fix NPT all npt temp 300 300 1 iso 0 0 0.1 drag 1
thermo_style custom step temp etotal vol lx ly lz press pxx pyy pzz
thermo_modify lost warn
thermo 1000
timestep 0.001
run 50000
reset_timestep 0
unfix NPT
fix temp all temp/berendsen 300 300 0.1
fix nve all nve
variable kb equal 1.3806504e-23
variable ev2J equal 1.60217e-19
compute ke all ke/atom
variable temp atom c_ke*{ev2J}/(1.5*{kb})
fix temp_profile_whole all ave/spatial 1 100000 100000 z -50 50 v_temp file temp.profile_whole units box # for whole structure
#calculate temperature difference between hottest and coldest regions
compute hottest_temp all temp/region up
compute coldest_temp all temp/region down
variable delta_temp equal c_hottest_temp-c_coldest_temp
fix delta_out all ave/time 1 100000 100000 v_delta_temp file delta_temp_graphene.dat
fix hottesttemp_out all ave/time 1 100000 100000 c_hottest_temp file hottesttemp_graphene.dat
fix coldesttemp_out all ave/time 1 100000 100000 c_coldest_temp file coldesttemp_graphene.dat
run 100001
unfix temp
fix heat_swap all thermal/conductivity 10 y 80
fix e_exchange all ave/time 10 1000 100000 f_heat_swap file e_exchange_graphene.dat
run 2000000
Best Regards,
Sarang
delta_temp_graphene.dat (384 Bytes)
temp.profile_whole.doc (1.73 KB)
graphene_thermal_conductivity.in (1.88 KB)
