Accurate fit of reference energies
Dear Axel,
I am unable to get an accurate fit of the reference energies via the cluster expansion, even though the CV score is low (0.020 eV) and the CE converges wrt cluster diameter. I have tried re-starting maps with the weight.in file that has a single column containing the weights in the same order as fit.out, but with a larger weight of 10 for the structures in the ref-dirs (i.e 0/ and 1/ for my case). But this file doesn’t seem to be read, as the resulting CV and fit.out shows a weight of 1 for all structures. I have also tried changing the weights to 0.1 instead of 10, but it doesn’t change the weights in fit.out.
Any suggestions? I am using MAPS v 2.86.
Ganesh
Exactly. Just make sure you do that after maps is done, otherwise your work will be overwritten.
Download the "Beta version of the latest update" at https://alum.mit.edu/www/avdw/atat/.
(2.86 did not have this feature).
You should see "weights.in file detected, reading user-specified weights." when you run.
BTW, you can always tweak the empty and point cluster after the fact to reproduce the exact end member energies.
Do you mean tweak the values in eci.out corresponding to empty and point clusters to get exact reference energies, right?
