Hi all,
I want to add a new compute, slip/atom, in the source code. I have generated compute_slip_atom.h and compute_slip_atom.ccp.
However, I got this error:ERROR: Illegal fix store command (…/fix_store.cpp:33)
and the job is aborted in the compute slip/atom command.
Could be please help me to figure out what can be the problem?
Leila
Hi all,
(../fix_store.cpp:33)
illegal XXX command means, that you didn't use the correct command line
arguments correctly.
if you look up line 33 of fix_store.cpp, where the error occurs, so see
that this happens due to an incorrect number of arguments.
