Advice needed for demo
I am working on a demo for our institute to show how nomad could help to document experimental procedures and improve FAIR-compliance.
The specific use-case is a PLD lab. The idea is to showcase the user-experience: a researcher creates a new sample, does a measurement, registers it in nomad, adds a reviewer and does some additional analysis using a jupyter notebook.
I have tried several approaches, but I haven’t been able to connect everything and make it all work.
The best I currently have:
The first issue I haven’t been able to solve is the csv processing.
The second problem is that I am unsure how to nicely tie everything together. The jupyter notebook and user management face no issues so far.
I would be happy with any tips/suggestions!
Kind regards,
Tim, DIFFER
Hi Tim, thanks for reaching out and sorry for the delay. It took me sometime to figure out the underlying issues. Generally speaking, using tabular annotations to parse data from csv/excel files is a bit tricky to get right. I will give the fixes for your current use-case followed by some recommendations.
All of these fixes are related to the schema definitions in sputtering_schema.archive.yaml.
  • In MandatoryGeometry, the base_sections used, “nomad.datamodel.metainfo.basesections.Section”, does not exist. Use “nomad.datamodel.data.ArchiveSection” instead.
  • In SputterDeposition, as data_file is a quantity, it should be defined under definitions.sections.SputterDeposition.quantities, rather than `definitions.sections.SputterDeposition`. Shifting the indentation by 2 spaces in the right should fix it.
  • Defaults provided for float type quantities should be int or float, not string. These should be fixed for MandatoryGeometry.diameter, SputterSampleParameters.distance_to_source, SputterStep.duration
Finally, here’s some very subtle issues related to TableData.
  • In SputterDeposition, the following order of base_sectionsresult in expected behaviour:
    • “nomad_material_processing.vapor_deposition.pvd.general.PhysicalVaporDeposition”
      • “nomad.datamodel.data.EntryData”
      • “nomad.parsing.tabular.TableData”
After making these fixes, I was able to create an entry with the custom YAML schema, upload the csv, and successfully parse the data into the entry upon processing.
Here’s a link to an upload I used for testing: https://nomad-lab.eu/oasis/gui/user/uploads/upload/id/SnumJ4LSSDiHz5IWHUcxPQ (this resource is not guaranteed to be persisted). You can copy the schema file content from https://nomad-lab.eu/oasis/gui/user/uploads/upload/id/SnumJ4LSSDiHz5IWHUcxPQ/files/sputtering_schema.archive.yaml/preview
Recommendations for handling CSV:
For a prototype as in your case, using the tabular annotations might be a good idea. But they are hard to get right by a normal user who simply wants to upload and parse data. In a production setting, I would suggest setting up plugin entry points for schema and using the schema normalizemethod to parse custom csv files. This would look something like:
class SputterDeposition(PhysicalVaporDeposition, EntryData):
  def normalize(self, archive: 'EntryArchive', logger: 'BoundLogger') -> None:
      Redefining the `normalize` method to read the data csv file and
      populate the quantities. This method is called when the entry
      is processed/saved.
      super().normalize(archive, logger)
      data_dict = {}
      if self.data_file is not None:
          data_dict = my_read_csv(self.data_file, archive, logger)
      if data_dict:
          self.write_data(data_dict, logger)
          # populate quantities and subsections with the extracted data
Hi Sarthak,
This has helped tremendously. Thank you very much.
Tim
