I’m trying to generate a stress-strain curve for a single layer of graphene sheet
at high temperatures.
I’m using a time step of 0.5fs and periodic boundary condition in all directions.
Since I’m simulating for single layer of graphene, i considering only the REBO
part by turning off the LJ and torsion term.
I want to equilibrate the system at 3300 K and 0.0 bar. So I used NPT ensemble
for equilibration. But it doesn’t works. “The simulation box size increases tremendously”.
I tried to control it by using different damping factor. But it is of no use.
The input script which I followed till 2400 K works fine. Compared with the results from
“Temperature and Strain-rate dependent fracture strength of graphene” , H.Zhao and N.R.Aluru,
Journal of Applied physics.
- fix 1 all npt temp 3300.0 3300.0 0.05 iso 0.0 0.0 0.5 drag 1.0
or
- fix 1 all langevin 3300.0 3300.0 0.05 12345
fix 2 all press/berendsen iso 0.0 0.0 1000.0 dilate partial
I tried the combination of langevin thermostat and berendsen barostat. Still i can’t able to
control the box dimension.
My question is:
- were these fixes (like Nose-hoover, langevin or berendsen) can be able to
simulate high temperature cases.
- Or there is some problem with REBO potential in simulating higher temperature cases?
I’m asking this because the sublimation/melting temperature of the graphene is above
4000 K.
Thanks in advance,
Ramki
I'm trying to generate a stress-strain curve for a single layer of graphene
sheet
I'm using a time step of 0.5fs and periodic boundary condition in all
directions.
Since I'm simulating for single layer of graphene, i considering only the
REBO
ensemble
for equilibration. But it doesn't works. "The simulation box size increases
tremendously".
use.
results from
"Temperature and Strain-rate dependent fracture strength of graphene" ,
1. fix 1 all npt temp 3300.0 3300.0 0.05 iso 0.0 0.0 0.5 drag 1.0
or
2. fix 1 all langevin 3300.0 3300.0 0.05 12345
i can't able to
My question is:
1. were these fixes (like Nose-hoover, langevin or berendsen) can be able to
There is no limitation on these fixes.
I would increase the temperature of the system in a more gradual way
rather than shooting it to 3300K instantly. E.g.
fix 1 all nve
fix 2 all langevin 300.0 3300.0 0.1 SEED
fix 3 all press/berendsen ...
Ray
