Dear Alex
I am trying to learn to use AMSET but I am getting an error like below. I did not understand the reason. can you help me ?
Examining material properties to determine possible scattering
mechanisms
Scattering mechanisms to be calculated: ADP, IMP, POP
Initializing deformation potential interpolator
ERROR: amset exiting on 22 Mar 2023 at 10:14
File "/Users/emb/miniconda3/bin/amset", line 8, in <module>
sys.exit(cli())
File "/Users/emb/miniconda3/lib/python3.8/site-
packages/click/core.py", line 1128, in __call__
return self.main(*args, **kwargs)
packages/click/core.py", line 1053, in main
rv = self.invoke(ctx)
packages/click/core.py", line 1659, in invoke
return _process_result(sub_ctx.command.invoke(sub_ctx))
packages/click/core.py", line 1395, in invoke
return ctx.invoke(self.callback, **ctx.params)
packages/click/core.py", line 754, in invoke
return __callback(*args, **kwargs)
packages/amset/tools/run.py", line 139, in run
runner.run()
packages/amset/core/run.py", line 65, in run
mem_usage, (amset_data, usage_stats) = memory_usage(
packages/memory_profiler.py", line 379, in memory_usage
returned = f(*args, **kw)
packages/amset/core/run.py", line 120, in _run_wrapper
amset_data, scattering_time = self._do_scattering(amset_data)
packages/amset/core/run.py", line 264, in _do_scattering
scatter = ScatteringCalculator(
packages/amset/scattering/calculate.py", line 111, in __init__
self.scatterers = self.get_scatterers(scattering_type,
settings, amset_data)
packages/amset/scattering/calculate.py", line 352, in
get_scatterers
return [
packages/amset/scattering/calculate.py", line 353, in <listcomp>
_scattering_mechanisms[name].from_amset_data(settings,
amset_data)
packages/amset/scattering/elastic.py", line 122, in from_amset_data
raise RuntimeError(
RuntimeError: Deformation potential file does not contain the
correct number of bands
Ensure it was generated using the same energy_cutoff as this AMSET
run.
resource_tracker: process died unexpectedly, relaunching. Some resources might leak.
File "/Users/emb/miniconda3/lib/python3.8/multiprocessing/resource_tracker.py", line 201, in main
cache[rtype].remove(name)
KeyError: '/mp-5z2o10ee'
