Amset run error uses GaAs in the example folder
I encountered many errors when testing amset with GaAs in the example folder. Can anyone help me solve this problem?
Thank you
Loading settings from: settings.yaml
                                                v0.4.20
  Ganose, A. M., Park, J., Faghaninia, A., Woods-Robinson,
  R., Persson, K. A., Jain, A. Efficient calculation of
  carrier scattering rates from first principles.
  Nat. Commun. 12, 2222 (2021)
amset starting on 25 May 2024 at 16:38
Run parameters:
  ├── scattering_type: auto
  ├── doping: [-3.e+13]
  ├── temperatures: [201 290 401 506 605 789 994]
  ├── bandgap: 3.1
  ├── soc: False
  ├── zero_weighted_kpoints: prefer
  ├── interpolation_factor: 50
  ├── wavefunction_coefficients: wavefunction.h5
  ├── use_projections: False
  ├── unity_overlap: False
  ├── free_carrier_screening: False
  ├── high_frequency_dielectric:
  │   [[ 10.32   0.00   0.00]
  │    [  0.00  10.32   0.00]
  │    [  0.00   0.00  10.32]]
  ├── static_dielectric:
  │   [[ 12.18   0.00   0.00]
  │    [  0.00  12.18   0.00]
  │    [  0.00   0.00  12.18]]
  ├── elastic_constant:
  │   [[ 139.7    0.0    0.0    0.0    0.0    0.0]
  │    [   0.0  139.7    0.0    0.0    0.0    0.0]
  │    [   0.0    0.0  139.7    0.0    0.0    0.0]
  │    [   0.0    0.0    0.0   69.8    0.0    0.0]
  │    [   0.0    0.0    0.0    0.0   69.8    0.0]
  │    [   0.0    0.0    0.0    0.0    0.0   69.8]]
  ├── deformation_potential: (1.2, 8.6)
  ├── defect_charge: 1
  ├── compensation_factor: 2
  ├── pop_frequency: 8.16
  ├── energy_cutoff: 1.5
  ├── fd_tol: 0.05
  ├── dos_estep: 0.01
  ├── symprec: 0.01
  ├── nworkers: -1
  ├── cache_wavefunction: True
  ├── calculate_mobility: True
  ├── separate_mobility: True
  ├── mobility_rates_only: True
  ├── file_format: json
  ├── write_input: False
  ├── write_mesh: True
  ├── print_log: True
  └── write_log: True
~~~~~~~~~~~~~~~~~~~~~~~~~~~~ STRUCTURE ~~~~~~~~~~~~~~~~~~~~~~~~~~~~
Structure information:
  ├── formula: GaAs
  ├── # sites: 2
  └── space group: F4̅3m
Lattice:
  ├── a, b, c [Å]: 4.07, 4.07, 4.07
  └── α, β, γ [°]: 60, 60, 60
~~~~~~~~~~~~~~~~~~~~~~~~~~ BAND STRUCTURE ~~~~~~~~~~~~~~~~~~~~~~~~~
Input band structure information:
  ├── # bands: 64
  ├── # k-points: 165
  ├── Fermi level: 2.776 eV
  ├── spin polarized: False
  └── metallic: False
Band gap:
  ├── direct band gap: 0.190 eV
  └── direct k-point: [0.00, 0.00, 0.00]
Valence band maximum:
  ├── energy: 2.674 eV
  ├── k-point: [0.00, 0.00, 0.00]
  └── band indices: 7, 8, 9
Conduction band minimum:
  ├── energy: 2.864 eV
  └── band indices: 10
~~~~~~~~~~~~~~~~~~~~~~~~~~ INTERPOLATION ~~~~~~~~~~~~~~~~~~~~~~~~~~
Getting band interpolation coefficients
  └── time: 7.6317 s
Interpolation parameters:
  ├── k-point mesh: 99x99x99
  └── energy cutoff: 1.5 eV
Interpolating spin-up bands 7-10
  ERROR: amset exiting on 25 May 2024 at 16:39
RuntimeError: Undefined plan with nthreads. This is a bug
Exception ignored in: 'pyfftw.pyfftw._fftw_plan_with_nthreads_null'
File "/home/phy1/.conda/envs/amset1/lib/python3.11/site-packages/pyfftw/builders/_utils.py", line 285, in _Xfftn
  FFTW_object = pyfftw.FFTW(input_array, output_array, axes, direction,
  └── time: 1.5871 s
bandgap set to 3.100 eV, applying scissor of 2.910 eV
Generating tetrahedron mesh vertices
  File "/home/phy1/.conda/envs/amset1/bin/amset", line 10, in
<module>
    sys.exit(cli())
packages/click/core.py", line 1157, in __call__
    return self.main(*args, **kwargs)
packages/click/core.py", line 1078, in main
    rv = self.invoke(ctx)
packages/click/core.py", line 1688, in invoke
    return _process_result(sub_ctx.command.invoke(sub_ctx))
packages/click/core.py", line 1434, in invoke
    return ctx.invoke(self.callback, **ctx.params)
packages/click/core.py", line 783, in invoke
    return __callback(*args, **kwargs)
packages/amset/tools/run.py", line 139, in run
    runner.run()
packages/amset/core/run.py", line 65, in run
    mem_usage, (amset_data, usage_stats) = memory_usage(
packages/memory_profiler.py", line 379, in memory_usage
    returned = f(*args, **kw)
packages/amset/core/run.py", line 114, in _run_wrapper
    amset_data, interpolation_time = self._do_interpolation()
packages/amset/core/run.py", line 204, in _do_interpolation
    amset_data = interpolater.get_amset_data(
packages/amset/interpolation/bandstructure.py", line 246, in
get_amset_data
    ) = get_kpoints_tetrahedral(
packages/amset/electronic_structure/kpoints.py", line 122, in
    grid_mapping, grid_address = spglib.get_ir_reciprocal_mesh(
packages/spglib/spglib.py", line 1569, in get_ir_reciprocal_mesh
    lattice, positions, numbers, _ = _expand_cell(cell)
packages/spglib/spglib.py", line 1999, in _expand_cell
    lattice = np.array(np.transpose(cell[0]), dtype="double",
order="C")
TypeError: float() argument must be a string or a real number, not
'Atom'
I have solved the problem, thank you.
I encountered same errors. How did you solve the problem?Can you help?
I have the same errors, please tell me how you solved them?
This has been fixed in v0.4.21
