Hi Alex,
I have faced the following error during the “amset run”. Can you please help me to identify the cause of error and solve the problem.
Thank you
Sampad
amset starting on 26 Dec 2022 at 03:49
Run parameters:
  ├── scattering_type: auto
  ├── doping: [-1.e+21 -5.e+20 -1.e+20 -5.e+19 -1.e+19 -5.e+18 -1.e+18 -5.e+17 -1.e+17
-5.e+16 -1.e+16 -5.e+15 -1.e+15  1.e+15  5.e+15  1.e+16  5.e+16  1.e+17
5.e+17  1.e+18  5.e+18  1.e+19  5.e+19  1.e+20  5.e+20  1.e+21]
  ├── temperatures: [ 200.  250.  300.  350.  400.  450.  500.  550.  600.  650.  700.  750.
800.  850.  900.  950. 1000.]
  ├── bandgap: 2.1351
  ├── soc: True
  ├── zero_weighted_kpoints: prefer
  ├── interpolation_factor: 10
  ├── wavefunction_coefficients: ./wavefunction.h5
  ├── use_projections: False
  ├── unity_overlap: False
  ├── free_carrier_screening: False
  ├── high_frequency_dielectric:
  │   [[  8.28   0.00   0.00]
  │    [  0.00   8.23   0.00]
  │    [  0.00   0.00   9.35]]
  ├── static_dielectric:
  │   [[ 10.94   0.00   0.00]
  │    [  0.00  10.90   0.00]
  │    [  0.00   0.00  12.94]]
  ├── elastic_constant:
  │   [[  42.5   22.9   27.6    0.0    0.0    0.0]
  │    [  22.9   42.5   27.6    0.0    0.0    0.0]
  │    [  27.6   27.6   44.4    0.0    0.0    0.0]
  │    [   0.0    0.0    0.0   18.8    0.0    0.0]
  │    [   0.0    0.0    0.0    0.0   18.8    0.0]
  │    [   0.0    0.0    0.0    0.0    0.0   13.9]]
  ├── deformation_potential: deformation.h5
  ├── defect_charge: 1
  ├── compensation_factor: 2
  ├── pop_frequency: 6.71
  ├── energy_cutoff: 1.5
  ├── fd_tol: 0.05
  ├── dos_estep: 0.01
  ├── symprec: 0.01
  ├── nworkers: -1
  ├── cache_wavefunction: True
  ├── calculate_mobility: True
  ├── separate_mobility: True
  ├── mobility_rates_only: False
  ├── file_format: json
  ├── write_input: True
  ├── write_mesh: True
  ├── print_log: True
  └── write_log: True
~~~~~~~~~~~~~~~~~~~~~~~~~~~~ STRUCTURE ~~~~~~~~~~~~~~~~~~~~~~~~~~~~
Structure information:
  ├── formula: XXX
  ├── # sites: 8
  └── space group: I4̅2d
Lattice:
  ├── a, b, c [Å]: 7.44, 7.44, 7.44
  └── α, β, γ [°]: 130, 130, 73
~~~~~~~~~~~~~~~~~~~~~~~~~~ BAND STRUCTURE ~~~~~~~~~~~~~~~~~~~~~~~~~
Input band structure information:
  ├── # bands: 50
  ├── # k-points: 70
  ├── Fermi level: 2.713 eV
  ├── spin polarized: False
  └── metallic: False
Band gap:
  ├── indirect band gap: 2.135 eV
  ├── direct band gap: 2.215 eV
  └── direct k-point: [0.00, 0.00, 0.00]
Valence band maximum:
  ├── energy: 2.275 eV
  ├── k-point: [0.00, 0.00, 0.00]
  └── band indices: 32
Conduction band minimum:
  ├── energy: 4.410 eV
  ├── k-point: [0.00, 0.00, 0.50]
  └── band indices: 33
~~~~~~~~~~~~~~~~~~~~~~~~~~ INTERPOLATION ~~~~~~~~~~~~~~~~~~~~~~~~~~
Getting band interpolation coefficients
  └── time: 0.1440 s
Interpolation parameters:
  ├── k-point mesh: 31x31x39
  └── energy cutoff: 1.5 eV
Interpolating spin-up bands 24-42
  └── time: 0.2565 s
bandgap set to 2.135 eV, applying scissor of 0.000 eV
Generating tetrahedron mesh vertices
  └── time: 0.1918 s
Initializing tetrahedron band structure
  └── time: 3.7592 s
Initializing momentum relaxation time factor calculator
Initializing wavefunction overlap calculator
Desymmetrizing k-point mesh
  ├── Found initial mesh: 1198.050 x 2096.612 x 4193.048
  ├── Integer mesh: 1198 x 2097 x 4193
  └── Using 16 symmetry operations
  ERROR: amset exiting on 26 Dec 2022 at 03:49
  File "/opt/intel/oneapi/intelpython/latest/bin/amset", line 33,
in <module>
    sys.exit(load_entry_point('amset==0.4.18', 'console_scripts',
'amset')())
  File "/opt/intel/oneapi/intelpython/latest/lib/python3.7/site-
packages/click/core.py", line 1130, in __call__
    return self.main(*args, **kwargs)
packages/click/core.py", line 1055, in main
    rv = self.invoke(ctx)
packages/click/core.py", line 1657, in invoke
    return _process_result(sub_ctx.command.invoke(sub_ctx))
packages/click/core.py", line 1404, in invoke
    return ctx.invoke(self.callback, **ctx.params)
packages/click/core.py", line 760, in invoke
    return __callback(*args, **kwargs)
packages/amset-0.4.18-py3.7.egg/amset/tools/run.py", line 139, in
run
    runner.run()
packages/amset-0.4.18-py3.7.egg/amset/core/run.py", line 71, in run
    multiprocess=True,
packages/memory_profiler-0.60.0-py3.7.egg/memory_profiler.py", line
 377, in memory_usage
    returned = f(*args, **kw)
packages/amset-0.4.18-py3.7.egg/amset/core/run.py", line 114, in
_run_wrapper
    amset_data, interpolation_time = self._do_interpolation()
packages/amset-0.4.18-py3.7.egg/amset/core/run.py", line 224, in
_do_interpolation
    self.settings["wavefunction_coefficients"]
packages/amset-0.4.18-py3.7.egg/amset/interpolation/wavefunction.py
", line 67, in from_file
    return cls.from_coefficients(coeff, gpoints, kpoints,
structure)
", line 80, in from_coefficients
    structure, kpoints, time_reversal=True, return_mapping=True,
symprec=symprec
  File "/opt/intel/oneapi/intelpython/latest/lib/python3.7/site-pac
kages/amset-0.4.18-py3.7.egg/amset/electronic_structure/symmetry.py
", line 157, in expand_kpoints
    raise ValueError(f"Expected {n_expected} points but found
{n_mapped}")
ValueError: Expected 10533679758 points but found 57
