Dear Lammps Users,
I just did “svn update” that suppose I got the last version. I did re-compile under /src and get errors with atc. Then I go back to /lib/atc and recompile the atc package, but get the same error information. Maybe some classes in lammps.h or others were missed, I guess. Many thanks for your help.
After doing “make no-USER-ATC”, the compilation was going very well.
[[email protected]…2538… atc]$ make -f Makefile.icc
icc -O -g -I/usr/local/mpich2/1.2.1p1/include -I…/…/src -DMPICH_IGNORE_CXX_SEEK -c ATC_HardyKernel.cpp
icc -O -g -I/usr/local/mpich2/1.2.1p1/include -I…/…/src -DMPICH_IGNORE_CXX_SEEK -c ATC_Transfer.cpp
icc -O -g -I/usr/local/mpich2/1.2.1p1/include -I…/…/src -DMPICH_IGNORE_CXX_SEEK -c ATC_TransferHardy.cpp
icc -O -g -I/usr/local/mpich2/1.2.1p1/include -I…/…/src -DMPICH_IGNORE_CXX_SEEK -c ATC_TransferThermal.cpp
icc -O -g -I/usr/local/mpich2/1.2.1p1/include -I…/…/src -DMPICH_IGNORE_CXX_SEEK -c ATC_TransferUtility.cpp
icc -O -g -I/usr/local/mpich2/1.2.1p1/include -I…/…/src -DMPICH_IGNORE_CXX_SEEK -c AtomicRegulator.cpp
icc -O -g -I/usr/local/mpich2/1.2.1p1/include -I…/…/src -DMPICH_IGNORE_CXX_SEEK -c ElasticTimeIntegrator.cpp
icc -O -g -I/usr/local/mpich2/1.2.1p1/include -I…/…/src -DMPICH_IGNORE_CXX_SEEK -c ElectronFlux.cpp
icc -O -g -I/usr/local/mpich2/1.2.1p1/include -I…/…/src -DMPICH_IGNORE_CXX_SEEK -c ElectronHeatCapacity.cpp
icc -O -g -I/usr/local/mpich2/1.2.1p1/include -I…/…/src -DMPICH_IGNORE_CXX_SEEK -c ElectronHeatFlux.cpp
icc -O -g -I/usr/local/mpich2/1.2.1p1/include -I…/…/src -DMPICH_IGNORE_CXX_SEEK -c ElectronPhononExchange.cpp
icc -O -g -I/usr/local/mpich2/1.2.1p1/include -I…/…/src -DMPICH_IGNORE_CXX_SEEK -c ExtrinsicModel.cpp
icc -O -g -I/usr/local/mpich2/1.2.1p1/include -I…/…/src -DMPICH_IGNORE_CXX_SEEK -c ExtrinsicModelTwoTemperature.cpp
icc -O -g -I/usr/local/mpich2/1.2.1p1/include -I…/…/src -DMPICH_IGNORE_CXX_SEEK -c FE_Element.cpp
icc -O -g -I/usr/local/mpich2/1.2.1p1/include -I…/…/src -DMPICH_IGNORE_CXX_SEEK -c FE_Engine.cpp
icc -O -g -I/usr/local/mpich2/1.2.1p1/include -I…/…/src -DMPICH_IGNORE_CXX_SEEK -c FE_Mesh.cpp
icc -O -g -I/usr/local/mpich2/1.2.1p1/include -I…/…/src -DMPICH_IGNORE_CXX_SEEK -c FieldEulerIntegrator.cpp
icc -O -g -I/usr/local/mpich2/1.2.1p1/include -I…/…/src -DMPICH_IGNORE_CXX_SEEK -c ImplicitSolveOperator.cpp
icc -O -g -I/usr/local/mpich2/1.2.1p1/include -I…/…/src -DMPICH_IGNORE_CXX_SEEK -c Kinetostat.cpp
icc -O -g -I/usr/local/mpich2/1.2.1p1/include -I…/…/src -DMPICH_IGNORE_CXX_SEEK -c LammpsInterface.cpp
LammpsInterface.cpp(401): error: class “LAMMPS_NS::Memory” has no member “create_1d_double_array”
return lammps_->memory->create_1d_double_array(nlo, nhi, name);
LammpsInterface.cpp(405): error: class “LAMMPS_NS::Memory” has no member “destroy_1d_double_array”
lammps_->memory->destroy_1d_double_array(d, i);
LammpsInterface.cpp(409): error: class “LAMMPS_NS::Memory” has no member “create_2d_double_array”
return lammps_->memory->create_2d_double_array(n1, n2, name);
LammpsInterface.cpp(413): error: class “LAMMPS_NS::Memory” has no member “destroy_2d_double_array”
lammps_->memory->destroy_2d_double_array(d);
LammpsInterface.cpp(421): error: class “LAMMPS_NS::Memory” has no member “grow_2d_double_array”
return lammps_->memory->grow_2d_double_array(array, n1, n2, name);
LammpsInterface.cpp(425): error: class “LAMMPS_NS::Memory” has no member “create_2d_int_array”
return lammps_->memory->create_2d_int_array(n1, n2, name);
LammpsInterface.cpp(429): error: class “LAMMPS_NS::Memory” has no member “destroy_2d_int_array”
lammps_->memory->destroy_2d_int_array(i);
LammpsInterface.cpp(433): error: class “LAMMPS_NS::Memory” has no member “grow_2d_int_array”
return lammps_->memory->grow_2d_int_array(array, n1, n2, name);
compilation aborted for LammpsInterface.cpp (code 2)
make: *** [LammpsInterface.o] Error 2
