An open band-gap model for 2D monolayers with a trust verdict, and label inconsistencies it found in Alexandria 2D
Hello all. I’m a nanoelectronics student and have been building an open tool for screening 2D semiconductors. I’d value this community’s view on both the method and the data issues below.
What it is. A five-member CGCNN ensemble (PyTorch Geometric) trained on 45k PBE monolayers - Alexandria 2D up to 1.0 eV/atom above the hull plus non-magnetic 2DMatPedia, all via JARVIS-Tools - that predicts the band gap from structure in under a second on a CPU. On a composition-disjoint test set of near-hull Alexandria monolayers it reaches MAE 0.19 eV; a Magpie + random-forest baseline gets 0.43 on the same set.
The verdict. Every prediction is tagged reliable / check / out-of-domain from three checks: a metal/semiconductor gate, the ensemble spread, and the distance to the training set in the model’s own latent space. Typical errors per tier are 0.10 / 0.17 / 0.35 eV, and the order holds on held-out metastable structures and on 2DMatPedia. The 90% interval is calibrated (91% coverage on the held-out test set). Linear heads on the latent space add G₀W₀-level and optical-gap estimates fitted on C2DB G₀W₀/BSE data, and a second ensemble predicts the work function, so both band edges can be placed against vacuum.
Data issues I ran into - possibly useful even if you never use the model:
  1. Planar honeycombs in Alexandria 2D. Graphene is labelled 1.23 eV in one cell and 1.13 eV in another, where C2DB, 2DMatPedia and JARVIS dft_2d all give 0; planar silicene 0.86 eV against 0.00 in 2DMatPedia for the same layer; planar BP 1.31 eV in a 2-atom cell and 0.906 in three larger cells of the same layer (C2DB 0.90). That pattern looks like a k-point mesh that misses K.
  2. Cell-dependent labels more generally. I found 62 structures stored in several Alexandria cells (same layer, same predicted gap to 0.05 eV) whose labels differ by more than 0.1 eV; in 37 of them the smallest cell has the highest gap. So the K-point explanation covers some of them but not all. The full list is in data/reference_flags.csv in the repository.
  3. Matching slabs across databases. StructureMatcher’s stol is normalised by (V/N)^(1/3), and in a slab V is mostly vacuum, so even tightened tolerances accept a planar and a buckled layer as the same structure (about 0.5 Å absolute). Requiring the layer thickness to agree within 0.2 Å fixed it; the threshold came from where the gap disagreement between matched pairs jumps (0.07 → 0.17 eV MAE).
  4. Spin-orbit coupling against C2DB. The model is 0.24 eV above C2DB on compounds containing an element with Z ≥ 52 and on target elsewhere, consistent with C2DB including SOC and Alexandria not.
Limits. PBE level without SOC; weakest on light-element chemistry (C, B, N, H), where training data is thin; the direct/indirect classifier is weak.
Browser with 28k precomputed predictions, filterable by application: https://ac1esan.github.io/nanomat-ai/ Code, model card, and the Colab notebook (MIT): https://github.com/ac1esan/nanomat-ai
I’d especially welcome corrections on points 1–2 from anyone who knows how the Alexandria 2D band structures were sampled, and on whether a verdict like this would be useful in your own screening work.
I’m learning about materials screening. How does your tool decide when to trust an answer and when to warn someone it might be wrong?
