Dear Lammps users,
Simulations are done for pulout of CNT from a stationary diamond matrix by applying discrete displacements. For that I made a loop to carry out displacements step by step. Although I am able to pullout the CNT from the matrix, I am not able to visualise it. Dump file generated is giving only the final coordinates of the CNT and matrix. Whereas I want to animate the whole thing. Can anyone help me out with this? Input file is given below -
units real
boundary p p s
atom_style atomic
neighbor 2.0 bin
neigh_modify delay 5
create geometry
lattice diamond 3.57
region diamondBox block 0 34 0 34 0 34 units box
create_box 1 diamondBox
create_atoms 1 region diamondBox
group matrix region diamondBox
mass * 12.0107
velocity all create 300.0 4928459 dist gaussian
LJ potentials
pair_style lj/cut 2.5
pair_coeff * * 1.0 1.0 2.5
region 1 cylinder z 17 17 3 0 34 units box
group cnt region 1
delete_atoms region 1 compress no
read_data data.CNT add merge shift 17 17 0
group CNT region 1
displace_atoms CNT move 0 0 9.33 units box
minimize 1.0e-4 1.0e-6 100 1000
min_style cg
velocity matrix scale 300.0 dist gaussian
fix
fix 1 matrix nvt temp 500 500 100
run 500
variable z equal 9.33
label my_loop
displace_atoms CNT move 0 0 0.05
variable z equal $z+0.05
#dump 2 all image 250 image.*.cfg type type zoom 1.6 adiam 1.5
if “$z <= 34” then “jump in.new my_loop”
print “Out of loop”
fix 2 all nvt temp 500 500 10
run 50
timestep 0.003
thermo 500
dump 1 all atom 500 dump.new
run 5000
print “WORKING”
Thanking you in advanceand regards!
Prasoon Singh
