Enumlib.jl is a from-scratch Julia reimplementation of enumlib, the derivative-structure enumeration code. This new implementation contains some important improvements over the original (see below). I am the author of the original Fortran, and this is meant to be its successor rather than a fork or a wrapper.
It is a drop-in replacement at the file level. It ships enum.x, polya.x and makestr.x, reads and writes the same struct_enum.in / struct_enum.out formats, and takes the same positional arguments. pymatgen’s EnumlibAdaptor drives it unchanged—pymatgen now documents Enumlib.jl as a source for enum.x and makestr.x, and detects which engine is installed via enum.x --version.
Three ways to install it:
- Julia:
Pkg.add("Enumlib")(registered in General, currently v0.4.0) - Standalone binaries, no Julia installation required, on the releases page: linux-x86_64, macOS arm64 and Windows, each with a
.sha256. The Linux build runs on glibc 2.17+, so it works on RHEL/Rocky and typical HPC nodes. - conda-forge: in review (staged-recipes#34550), not yet available.
The algorithms are the same ones: HNF/SNF supercell enumeration and Pólya counting (HF 2008); multilattices (HF 2009); concentration-restricted enumeration by multinomial hashing (HNF 2012); the recursive-stabilizer tree for high configurational freedom (MHF 2017).
What is actually new, beyond being in Julia:
You can find out how big an enumeration is before committing to it. count_inequivalent returns the exact number of symmetry-distinct structures by Pólya/Burnside counting without generating any of them, broken down per supercell volume and per concentration. Counting is not itself new—the Fortran shipped a polya.x, and so does this—but three things about it are. The count is correct when sites are restricted, which the Fortran’s is not (see the divergence below). It is an ordinary function you can call in the middle of a program, not a separate executable you shell out to. And estimate_cost turns it into a predicted peak memory, so an enumeration that could never finish is refused up front, with the numbers, instead of dying three hours in—there is no equivalent of that gate in the Fortran.
For scale, from a head-to-head against the Fortran on an hcp ternary case: at n=8 the Fortran took about 9.3 minutes to enumerate 49,947,870 structures, and count_inequivalent returns that same number in about 0.1 s. At n=9 the answer is 335,918,026, which the Fortran run could not reach inside its time budget at all. Counts agreed exactly at every volume from 1 to 8. That is counting versus enumerating, not a like-for-like speed comparison. The point is not that one is faster than the other: it is that “how big is this?” stopped being a question you have to run the job to answer.
using Enumlib
parent = ParentLattice([0.5 0.5 0.0; 0.5 0.0 0.5; 0.0 0.5 0.5])
sites = Sites([Site([0.0, 0.0, 0.0], [0, 1])])
count_inequivalent(parent, sites; supercells = VolumeRange(1:12)) # answer in ms
estimate_cost(parent, sites; supercells = VolumeRange(1:12)) # and what it would cost
e = enumerate_structures(parent, sites; supercells = VolumeRange(1:8))
The algorithm is chosen for you. :auto dispatches between the 2012 multinomial-hash and the 2017 recursive-stabilizer tree based on the case in front of it, rather than leaving you to flip origCrossOutAlgorithm and hope. You can still name one explicitly.
Site restrictions are first class. Per-site allowed_labels mean zinc-blende, half- and full-Heusler, perovskite and spinel-type problems are stated directly rather than encoded around. Per-sublattice concentrations go with them: Concentration(sites, per_sublattice) lets you say “1:1 on the A site, 1:1 on B, O fixed” instead of hand-computing a global composition vector. This is also the area where the counting differs from the Fortran—see below.
There is a DFT round trip, not just structure files. to_poscar writes VASP-5 (gh: isthere a difference between vasp5 and vasp6 files? If not we should list both.) POSCARs that carry their own provenance in the comment line; write_enumeration_archive packages a whole enumeration with a manifest; and read_results / attach_results bring computed energies back and attach them to the structures they came from. The “Build a DFT training database” tutorial walks the whole loop, which is the part I most wanted for cluster-expansion work and never had in the Fortran.
It is a library, not only a program. Structures are Julia values you compose with—no temp files, no parsing struct_enum.out, no shelling out. The .x executables exist for interoperability with existing Python workflows, not because that is the intended way to use it.
It is documented and anchored. Tutorials, how-to pages and explanations of each algorithm with citations, and the examples in them are executed as doctests in CI rather than being aspirational. Counts are locked in the test suite against Fortran-generated references across fcc, hcp, diamond, zinc-blende, both Heuslers and perovskite.
One deliberate difference in results, which you should know about if you compare outputs. For symmetry-equivalent sublattices with overlapping label sets, Enumlib.jl keeps symmetry operations that the Fortran drops, so the two can report different counts. It shows up whenever two symmetry-equivalent sublattices carry different or overlapping species sets: diamond with [0,1,2] on one and [0,1] on the other gives 6 / 27 / 170 at n=1,2,3 where the Fortran gives 5 / 23 / 151, and the wurtzite 3-vs-4 case has the same root cause. My claim is that the Fortran is wrong there—a parent operation that swaps two sublattices carrying different species is not a symmetry of the labeled configuration, and the Fortran predates per-site allowed_labels support. Everything else we have run head-to-head matches exactly.
Docs: https://glwhart.github.io/Enumlib.jl Source: GitHub - glwhart/Enumlib.jl: Julia successor to the Fortran enumlib: derivative-structure / superlattice enumeration with colorings and symmetry reduction. · GitHub Source: GitHub - glwhart/Enumlib.jl: Julia successor to the Fortran enumlib: derivative-structure / superlattice enumeration with colorings and symmetry reduction. · GitHub
