Dear users,
I am a new lammps user and I want to know if there is any way to apply electric field on the particles with gayberne pair-style. I am assuming particles don’t have any charge and the applied electric field induces dipole-moment to the ellipsoids.
Thanks in advance.
Regards
Dear users,
particles don't have any charge and the applied electric field induces
i am not aware of an existing feature, that can do this.
thus in order to realize such a model, you would have to program your own
custom fix style to apply the required force/torque to the particles.
axel
You can assign point dipoles to spheroids or ellipsoidal particles. See
the atom_style dipole command. Then you could use pair hybrid
to use (a) pair gayberne for the LJ-like ellipsoidal interactions,
and (b) pair lj/cut/dipole/cut to do the dipole/dipole interactions,
with the LJ terms in that potential set to epsilon=0.0. Or dipole/long
with ewald.
We should probably add a simple pair dipole/cut and dipole/long
to make this easier to add dipole interactions to any potential.
Looks like we also need to add a “dipole” keyword to fix nve/asphere
(like for fix nve/sphere) to update the dipole direction when the
ellipsoid rotates.
with ewald.
that would still require to write a fix to compute/update the dipole
according to a polarizability tensor as indicated in the original post.
axel
I assumed this comment in the original post meant the user
would assign a fixed magnitude dipole moment to the particles
and wants the applied E-field to interact with it. LIke a Stockmeyer
model, but for ellipsoids.
It instead, as Axel indicates, you want some form of a true polarizable potential,
then LAMMPS does not have those, even for spherical paritlces,
other than what is part of the COMB potentials.
Thanks for the reply and comments.
pair lj/cut/dipole/cut can be used if i have predefined fixed dipole moment values of particles, but here I want electric field to couple with long axis of the ellipsoid and update the dipole moment accordingly at every step as Axel has indicated in his reply.
If you want fix efield to interact with individual dipole moments and adjust their length,
then writing a derived class from fix efield that includes this effect is easy to do.
That is, if the comptuation involves the Efield and a single dipole and it changes
the length of the dipole (or also induces a torque, which is what fix efield currently does).
If the calculation is a collective effect involving many dipole moments, then that’s
more like a polarizable force field and would need to be implemented as a pair style.
