I have an issue with the displacement field of two different configurations (final and initial coordinates are in the same .xyz file). It happens that when adding the modifications of displacement vectors, I am not able manipulate the arrow width (which in the attached figure shows as 5, but if I change to any other value, there are no changes in the plot). Could you please help me with this problem?
We were unable to reproduce this error on our end. Could you please provide the structure file and the OVITO state file? You can either share them here or send them to [email protected] if you prefer not to make them public.
One more thing - I noticed that you set the arrow transparency to 1.3%. Having a small but nonzero transparency can increase rendering times, since the rendering pipeline must switch to a mode that supports transparent objects. This typically causes a performance hit without any noticeable visual difference. Therefore, I recommend setting the transparency either to 0% or to a more significant value if transparency is desired.
