I’m trying to create nanotwinned coherent boundaries(CTBs) by lammps but it doesn’t work for a long time.
To make the twin plane ,ie. the (111) plane in fcc crystal, vertical to a plane of simulation box(such as x-o-y plane), I choose .[a1,a2,a3]=as primary vector of original crystal and [a1,a2,a3]=as primary vector of twin crystal. However, there’re 2 problem i cannot fix.
1.Atoms on the edge of the simulation box disappeared for no reason.
2.The lammps shuts down unexpectedly when running this script because of the error:segementation fault.
fig. The twin crystal appears to be correct except some atoms are lost for unknown reason at the center of the simulation box,as shown in the left picture. Besides, atoms on the edge of x orientation of the box are all lost, making it aperiodicity on x orientation(It’s periodical on y and z orientation). The aperiodicity will be more obvious when drag atoms around in the box by AtomEye,as showed in the right picture.
-------------------partial lammps script------------
#initiallization
atom_style atomic
#create a tilt lattice for twin crystal
variable box_x equal 1.732050807568877293527446341505910#
variable box_y equal 1.224744871391589049098642037352920#
variable box_z equal 1.4142135623730950488016887242097*3#
#create box
lattice fcc 3.61
region box block -{box_x} {box_x} 0 {box_y} 0 {box_z}
create_box 1 box
#create atoms
region t1 block -{box_x} 0 0 {box_y} 0 {box_z}
region t7 block 0 {box_x} 0 {box_y} 0 {box_z}
lattice custom 3.61 a1 0.57735027 -0.5 0.70710687 a2 0.57735027 -0.5 -0.70710687 a3 0.57735027 0.72474487 0 basis 0 0 0 basis 0.5 0.5 0 basis 0.5 0 0.5 basis 0 0.5 0.5
create_atoms 1 region t1
lattice custom 3.61 a1 -0.57735027 -0.5 0.70710687 a2 -0.57735027 -0.5 -0.70710687 a3 -0.57735027 0.72474487 0 basis 0 0 0 basis 0.5 0.5 0 basis 0.5 0 0.5 basis 0 0.5 0.5
create_atoms 1 region t7
group t1 region t1
group t7 region t7
#calculation
pair_style eam/alloy
pair_coeff * * mg.eam.alloy Mg
neighbor 0.8 bin
neigh_modify every 5 delay 0 check yes
thermo 10
variable N equal atoms
variable E equal pe
timestep 0.01
compute 3 all pe/atom
compute 4 all ke/atom
compute 5 all coord/atom 3.0
dump 1 all cfg 1000 t*.cfg id type xs ys zs c_3 c_4 c_5
min_style sd
minimize 1.0e-30 1.0e-15 10000 100000
print “----------fcc_hcp---------------N=$N E=$E------------------------”
