I want to ask a question about tuning LAMMPS efficiency by using the command - processors.
I tried multiple combination of processors commands by using the sample “in.chute.scaled”, but I found out it made no much big difference.
- processors.
"in.chute.scaled", but I found out it made no much big difference.
Did I choose a bad input sample for testing?
Could you please teach me the
tip of using this command?
the processors keyword is primarily useful
when you have a load imbalance and when
you run across a large number of multi-core
(NUMA) nodes. with 12 MPI tasks and an
input that has a fairly homogeneous distribution
of particles in space, neither of those conditions
is met, so there is no surprise that you don't
see significant changes.
