I’m currently using LAMMPS as part of a proton transfer simulation, and in the course of the simulation, I need to extract the energy of the system at two different configurations (based on proton location) during each time step. The way I was doing this originally, which appears to work, was to use the LAMMPS library interface with the following sequence of commands:
run 1 (to propagate system)
reset proton coordinates to state 1
run 0 (to get potential energy)
reset proton coordinates to state 2
run 0
revert to original coordinates and continue simulation
Of course, this required each step to be propagated separately, and the method is relatively slow. In the interest of speed and simplifying the interface, I’ve been working to develop a compute that would perform the same calculation during each time step automatically, without requiring additional communication from an external program. Schematically, the relevant bit of my existing compute code looks something like:
Compute * potential = modify->compute[pe_index];
move_atom(x1);
first_energy = potential->compute_scalar();
move_atom(x2);
second_energy = potential->compute_scalar();
Although I’ve checked that the functions are moving the proper atom to the correct location, it appears that the potential energy is not updated between calls, so I wind up with both energy values identical for every step, which is obviously wrong, and conflicts with known results using the previous library method. I’ve tried doing a few things to force a recalculation of the energy, but haven’t had any luck so far and I was wondering if someone could help me figure out how to tell the pe compute to reset between my evaluation at states 1 and 2?
I’ve looked through the relevant source files for the pe compute, and the verlet and integrate modules, but I’m not entirely clear on how these manage to require an update on each time step.
Thomas Allen
