LAMMPS has an option to output forces on atoms:
http://lammps.sandia.gov/doc/compute_property_atom.html
Ray
Ray
And this force should be averaged on time and space domain through fix ave/spatial.
Ray
Not necessarily. Adhesive force between two slabs is the difference
between sums not averages.
Ray.
Difference between the sums.
Well, as I think the compute property/atom computes the values corresponding to each atoms. On the other hand, in MD simulations there a statistic behavior and we should average in the time and space domains in order to find the real values. Then, we can multiply this value by the number of atoms. May be “fix ave/spatial” is better than the “compute reduce sum” in the way that the first averages on the time and space.
In summery, compute stress/atom and then fix ave/spatial and finally multiplying the output of this fix by the volume of each bin can take the stress.
Am I wrong?
Ray.
Okay, you did not say you will multiply this averaged value by the
number of atoms. If you don't multiply by the number of atoms, then
it is not correct.
Then what is the difference between "sum of forces on all atoms" and
"average of forces on all atoms multiplied by the number of atoms"?
Same, right? So you can do it both ways.
Ray
