Dear Axel,
I want to add a force according to something like this formula to EACH ATOM : Fx=vx0.01+x0.04
and I want to use “fix add force” command to do that.
but I get this error " atom vector in equal style variable formula."
Regards
Dear Axel,
Regards
First of all I would recommend reading the variable section of the manual. you can use fix store/state, store the coordinate and use it as an variable. For example:
fix fixID groupID store/state 1 x y z
variable X atom "f_fi1[1]"
variable Y atom "f_fi2[2]"
variable F_x atom "*Formula*"
run 0
unfix fixID
I believe you can use the formula with fix addforce.
Vinit
there is no need to use fix store/state to access per-atom properties
like coordinates or velocities. please see the variable command docs.
Dear Vinit,
Thanks for your expanded reply, It helps me alot and I got my answer.
P.s. thanks to Dear Axel, as he said there is no need to use fix store/state.
Regards,
Sam
