Hi Bharat,
And how different is atomate from MPWorks?
atomate is essentially intended to be a better version of MPWorks, and will likely replace MPWorks soon. The number of changes is too much to detail but some examples:
atomate does a much better job of MPWorks of not mixing in execution with the real content of the workflow. It has features like “env_chk” that help with this
MPWorks requires 4 databases (SNL, submissions, FireWorks, output), whereas atomate only has 2 (FireWorks, output) - and even the latter is usually optional.
atomate is much more modular in terms of building up workflows and really having reusable components
the code is much clearer
there are additional features like builders in there
various improvements like more clear task documents vs MPWorks
more workflows are implemented
How difficult would it be to add support for either of the DFT calculators in atomate, so I can plan the timeline?
I can’t tell you how long it would take you to implement a workflow, especially given that I have no knowledge of what that workflow will be. I think it is best if you look at the code and try to make an estimate for yourself. Note that many people have now contributed what I would call moderately complex workflows and it usually doesn’t take very long.
Anubhav
On Tuesday, May 9, 2017 at 2:12:49 PM UTC-7, Bharat Medasani wrote:
Hello Anubhav,
For one of my next projects, I am looking at running a moderately complex workflow using either NWChem or CP2K.
