Atoms are blowing away from simulation box
Dear Concerns
I am new in Lammps. Currently I am trying to fix room temperature (300K) of my substrate and apply velocity on particle. for this I tried several ways to fix my problem. I have two parts of simulation. (1) set room temperature (2) apply velocity in restart file. Here I am describing…
Case 1: I tried with NVT with gaussian distribution to fix room temperature. But found after some time steps Cu atoms are blowing from lower parts of simulation box, which I have attached in pic 1.
velocity all create 300.0 3213112 mom yes rot yes dist gaussian
fix 2 all nvt temp 300 300 100
Case 2: Then I tried with NVT and Langevin. I found same as case 1.
Case 3: Finally I tried with NVE and langevin. In this case I got good result and atoms are not blowing (see the attached pic 2 for temperature profile) below also input script
LAMMPS Input File
---------- Initialize Simulation ---------------------
boundary p p f
atom_style full
---------- Create Atomistic Structure ---------------------
read_data system1.LAMMPS05
group substrate type 1
group graphite type 2
region wall block INF INF INF INF -8.1500 -7.1529 units box
group bottom region wall
region middle block INF INF INF INF -7.1529 7.287090 units box
group stable region middle
region upper block INF INF INF INF 7.287090 106.802002 units box
group top region upper
region upper2 block 0.173601 99.448601 -0.966524 98.308502 28.947100 30.752100 units box
group surface region upper2
#fix 1 stable setforce 0.0 0.0 0.0
---------- Define Interatomic Potential ---------------------
pair_style hybrid eam lj/cut 8.0 airebo 4.0 0 0
pair_coeff * * airebo CH.airebo NULL C
pair_coeff 1 1 eam Cu_u3.eam
pair_coeff 1 2 lj/cut 0.00996 3.225
neighbor 2.0 bin
neigh_modify delay 10 check yes
---------- Run Minimization ---------------------
timestep 0.001
fix 2 substrate nve
#velocity all create 300.0 5812775 mom yes rot yes dist gaussian
#fix 2 all npt temp 300 300 100 iso 0 0 100
fix 3 substrate langevin 300 300 0.01 699483
#fix 3 all nvt temp 300 300 100
thermo 100
compute surface_temp substrate temp
compute surface_ke substrate ke
thermo_style custom step c_surface_temp c_surface_ke lx ly lz etotal
#thermo_style custom step temp ke pe lx ly lz etotal
#thermo_modify lost ignore
dump 1 all xyz 500 system_1313.xyz
restart 150000 deposite.restart
run 150000
Case 4: With this restart file I tried to apply velocity in z axis. But I observing some atoms lost from the simulation box like case 1. Here is my input file for apply velocity
LAMMPS Input File
boundary p p f
atom_style full
lattice fcc 1.0
read_restart deposite.restart.150000
pair_coeff 1 2 lj/cut 0.07 3.225
neighbor 2.0 bin
timestep 0.001
#velocity top create 300.0 3213112 mom yes rot yes dist gaussian
#fix relax top nvt temp 300 300 0.01
fix 2 substrate nve
thermo 100
compute surface_temp surface temp
compute surface_ke surface ke
velocity graphite set 0.0 0.0 -3.5
dump 1 all xyz 500 system_1_langen2.xyz
run 100000
For my simulation I don’t want to set z axis as periodic. At this moment I have no idea how I can apply velocity correctly. I am really expecting some fruitful comments or commands to solve my problem. Actually why atoms are blowing away ? Thanks in advance.
Regards
Nasim
RA at UOU
Your scripts are useless without the relevant data/restart files.
About case 2: You should not use both fix nvt and fix langevin, as they will both attempt to thermostat your system which is probably a bad idea. This is actually mentioned here: http://lammps.sandia.gov/doc/fix_langevin.html
Now for the real problem: I cannot check if your dynamics are good because you did not supply the data files, but even if they are, you are going to lose atoms if you give them a velocity in the z-direction if your boundary is “f”. LAMMPS will error as soon as one atom leaves the simulation box through the z-direction. If you would add the thermo_modify lost ignore command that you have commented out, the error will probably go away. Alternatively, you can set the boundary to “s”, so that LAMMPS can rescale the box so that all atoms will fit inside at all times.
actually mentioned here: LAMMPS Molecular Dynamics Simulator
is "f". LAMMPS will error as soon as one atom leaves the simulation box
Alternatively, you can set the boundary to "s", so that LAMMPS can rescale
neither of these two suggestions are a good approach for the specific
problem at hand. ignoring lost atoms is something that often hides a
bigger problem and should only be enabled with you deliberately desire
to have atoms leave the cell.
similarly using "s" boundaries are just addressing the symptom and
will in addition lead to load imbalances and thus inefficient
simulation.
for a solid slab system there should no atoms leaving the slab. if
they do, there is a problem with the initial geometry or the potential
parameters. that being said, it is often considered cleaner, to keep
the lowest 1-2 layers of atoms immobile, so they don't reconstruct and
more closer resemble a bulk system. and then place a (dissipative)
thermostat on the several layers of atoms above it, to simulate the
exchange of kinetic energy with bulk, and then have the topmost layers
run un-thermalized after initial equilibration. this is the approach
followed in several publication and has been suggested and discussed
on this list multiple times.
​Thanks to all, specially to Axel. It is working now…​
