If you do the calculation with lammps, the atoms in the liquid and solid phases will be mixed. Please let me know how to resolve this.
The current in-file is as follows
Defining the system
atom_style atomic
read_data lammps.dat
#group Si type 1
#group Cr type 3
#group C type 2
group kotei id 7 8 9 10 17 18 19 20 29 30 31 32 39 40 41 42 49 50 51 52 59 60 61 62 71 72 73 74 81 82 83 84 91 92 93 94 101 102 103 104 113 114 115 116 123 124 125 126 133 134 135 136 143 144 145 146 155 156 157 158 165 166 167 168
group sp id 1 2 3 4 5 6 11 12 13 14 15 16 21 22 23 24 25 26 27 28 33 34 35 36 37 38 43 44 45 46 47 48 53 54 55 56 57 58 63 64 65 66 67 68 69 70 75 76 77 78 79 80 85 86 87 88 89 90 95 96 97 98 99 105 106 107 108 109 110 111 112 117 118 119 120 121 122 127 128 129 130 131 132 137 138 139 140 141 142 147 148 149 150 151 152 153 154 159 160 161 162 163 164
pair_style nnp
pair_coeff * * ffield.sannp eatom zero Si Cr C
velocity all create 1873.0 15180
Statistical properties
#reset_timestep 0
compute RDF all rdf 60 1 1 1 3 1 2 3 1 3 3 3 2 2 1 2 3 2 2 cutoff 6.0
#fix rdfAve all ave/time 4135 1 4135 c_RDF[*] mode vector file lammps.rdf
ave/time N1 N2 N3
compute md1 Si msd
#fix msd1 all ave/time 4135 1 4135 c_md1[*] file Si.msd
compute md2 C msd
#fix msd2 all ave/time 4135 1 4135 c_md2[*] file C.msd
compute md1 C msd
#variable msdx equal c_md1[1]
#variable msdy equal c_md1[2]
#variable msdz equal c_md1[3]
#variable msd equal c_md1[4]
#variable istep equal step
#fix md1 all print 1 “{istep} {msdx} {msdy} {msdz} ${msd}” screen no file msd_C.dat
Setting for output
dump Dump all custom 1 tmpdir/lammps.dmp type x y z
thermo_style custom step time cpu pe ke etotal enthalpy temp press vol density cella cellb cellc cellalpha cellbeta cellgamma
thermo 1
Setting to run MD or minimization
>>> SCHEME-1
fix ensemble all nvt temp 1873.0 1873.0 0.001
fix kosou kotei setforce 0.0 0.0 0.0
fix ko sp spring/self 50
timestep 2.41837968e-03
run 4135
unfix ensemble
