I already have the vasprun file, taken from the example directory provided by amset.
I tried to run the command => amset run --interpolation-factor 20 , which gives an error that copied below.
Any help how to solve this can be appreciated. Thank you.
–print-log / --no-log whether to print log messages
-h, --help Show this message and exit.
(power) Arpitas-MacBook-Pro:_K_50 arpita$ python xx.py
File “xx.py”, line 1, in
from amset.core.run import AmsetRunner
File “/Users/arpita/anaconda3/envs/power/lib/python3.8/site-packages/amset/core/run.py”, line 26, in
from amset.scattering.calculate import ScatteringCalculator
File “/Users/arpita/anaconda3/envs/power/lib/python3.8/site-packages/amset/scattering/calculate.py”, line 47, in
“triangle”: quadpy.t2.xiao_gimbutas_50(),
AttributeError: module ‘quadpy.t2’ has no attribute ‘xiao_gimbutas_50’
(power) Arpitas-MacBook-Pro:_K_50 arpita$ pip install quadpy
Requirement already satisfied: quadpy in /Users/arpita/anaconda3/envs/power/lib/python3.8/site-packages (0.16.2)
Requirement already satisfied: sympy in /Users/arpita/anaconda3/envs/power/lib/python3.8/site-packages (from quadpy) (1.6.2)
Requirement already satisfied: scipy in /Users/arpita/anaconda3/envs/power/lib/python3.8/site-packages (from quadpy) (1.5.2)
Requirement already satisfied: numpy in /Users/arpita/anaconda3/envs/power/lib/python3.8/site-packages (from quadpy) (1.19.1)
Requirement already satisfied: ndim in /Users/arpita/anaconda3/envs/power/lib/python3.8/site-packages (from quadpy) (0.1.4)
Requirement already satisfied: orthopy<0.9,>=0.8.3 in /Users/arpita/anaconda3/envs/power/lib/python3.8/site-packages (from quadpy) (0.8.4)
Requirement already satisfied: mpmath>=0.19 in /Users/arpita/anaconda3/envs/power/lib/python3.8/site-packages (from sympy->quadpy) (1.1.0)
(power) Arpitas-MacBook-Pro:_K_50 arpita$ ls
vasprun.xml xx.py
(power) Arpitas-MacBook-Pro:_K_50 arpita$ amset run --interpolation-factor 20
File “/Users/arpita/anaconda3/envs/power/bin/amset”, line 8, in
sys.exit(cli())
File “/Users/arpita/anaconda3/envs/power/lib/python3.8/site-packages/click/core.py”, line 829, in call
return self.main(*args, **kwargs)
File “/Users/arpita/anaconda3/envs/power/lib/python3.8/site-packages/click/core.py”, line 782, in main
rv = self.invoke(ctx)
File “/Users/arpita/anaconda3/envs/power/lib/python3.8/site-packages/click/core.py”, line 1259, in invoke
return _process_result(sub_ctx.command.invoke(sub_ctx))
File “/Users/arpita/anaconda3/envs/power/lib/python3.8/site-packages/click/core.py”, line 1066, in invoke
return ctx.invoke(self.callback, **ctx.params)
File “/Users/arpita/anaconda3/envs/power/lib/python3.8/site-packages/click/core.py”, line 610, in invoke
return callback(*args, **kwargs)
File “/Users/arpita/anaconda3/envs/power/lib/python3.8/site-packages/amset/tools/run.py”, line 105, in run
