I need to compute the average of the SQUARED energy
(Kinetic+Potential) over a certain interval of time in a dynamic
simulations:
<E_total^2>
I have seen how to compute the average of the kinetic and potential
energy independently.
But I couldn't find on the manual how to define variables on their sum
and squares.
Is it possible to define a quantity
E_tot = kinetic+potential
and then
E_square = E_tot*E_tot
and then use ave and reduce
What precise voice of the manual should I look at ?
How is the syntax ?
Any suggestions ?
In addition, how can I print the average of the distance between all
couples of atoms <r_ij> ?
And its square <r_ij^2> ?
Is it possible with ave and reduce ?
I have found just the command for the displacement from its original coordinates
compute displace/atom, but that is not what I need...
Thank you in advance for your help.
Bests,
Daniele Scopece
The first part is easy: You can define variables that do this, e.g.:
variable U equal pe
variable K equal ke
variable E equal “v_U + v_K”
variable E2 equal “v_E*v_E”
etc…
These can then be averaged with fix ave/time.
The second part is more difficult, and I am not sure if it is possible without modifications. There is a compute pair/local which gives distances between atoms involved in pairwise interactions, which you can dump or compute with dump/local and compute/local. Constructing the full NxN matrix of distances is more difficult though, and to me it seems that this is way easier in post-processing.
Compute reduce can take the output of compute pair/local (for distance)
and average it to a single value. You could also use fix ave/histo with
output from pair/local to calc a histogram of distances.
Neither can do those operations on the square of distances, and
there is no variable option that works for “local” values. I guess
either compute pair/local or compute reduce would need a new option
to create a squared quantity.
Keep in mind your r and r^2 descriptors for point 2 may turn out to scale with system size. At least that is the case of a homogeneous system (constant number density).
Radial intergration gives:
= \int r * P® dr = \int r * 4\pi*r^2/V_tot dr = 4\pi/V_tot * \int r^3 dr
using V_tot ~ r_max^3
one gets for ~ r_max a linear dependency with r_max being the maximum integration radius.
Carlos
PS: you may want to check my “fast food” approach to the calculation
Added a sumsq and avesq option to compute reduce.
Will be in the next patch.
