I am trying to simulate spc/e water flow through a channel with wall molecules in z direction. periodic boundary condition is applied in all directions. I set the wall temperature via nvt also nve ensemble is used for water molecules. but after few steps, the water molecules approach to the walls and a vacant space appears at the middle of the domain.
I was wandering what is the reason of wrong distribution of water molecules inside the domain.
inside the domain.
bad, non-equlibrated setup?
bad parameters?
typos in the input?
errors in the input?
lots of possibilities. usually, the probability to mess something up
list larger than to get it right.
Dear Dr. Kohlmeyer, thanks for reply
i don’t know my setup is right for equilibrium or not. I checked the rest over and over.
here is the main part of equilibrium step in my input:
do you think this gonna work to equilibrium the explained system?
Regards,
Dear everyone
inside the domain.
bad parameters?
typos in the input?
If it’s a hydrophilic wall-water interaction, it might not be surprising to find the density of water overall should be higher than the liquid density. And since there’s no way in your system for the box size to change you have to lose molecules from somewhere…
