Hi Alex,
Thank you for your reply. Below are all messages generated during the calculation:
test_job.error: empty
test_job.out:
2020-11-13 13:55:51,521 INFO Hostname/IP lookup (this will take a few seconds)
2020-11-13 13:55:51,539 INFO Launching Rocket
2020-11-13 13:56:32,007 INFO RUNNING fw_id: 1 in directory: /global/u1/w/wygong/wf/test/Si_static
2020-11-13 13:56:32,033 INFO Task started: FileWriteTask.
2020-11-13 13:56:32,043 INFO Task completed: FileWriteTask
2020-11-13 13:56:32,047 INFO Task started: FileWriteTask.
2020-11-13 13:56:32,052 INFO Task completed: FileWriteTask
2020-11-13 13:56:32,056 INFO Task started: {{atomate.vasp.firetasks.write_inputs.WriteVaspFromIOSet}}.
2020-11-13 13:56:32,333 INFO Task completed: {{atomate.vasp.firetasks.write_inputs.WriteVaspFromIOSet}}
2020-11-13 13:56:32,337 INFO Task started: {{atomate.vasp.firetasks.run_calc.RunVaspCustodian}}.
std_err.txt: empty
launchpad-debug.log:
2020-11-13 12:30:12,476 DEBUG RESTARTED fw_id, launch_id to (1, 1)
2020-11-13 12:30:12,479 INFO Performing db tune-up
2020-11-13 12:30:12,479 DEBUG Updating indices…
2020-11-13 12:30:12,509 INFO LaunchPad was RESET.
2020-11-13 12:30:33,919 INFO Added a workflow. id_map: {-1: 1}
2020-11-13 12:30:48,267 DEBUG FW with id: 1 is unique!
2020-11-13 13:56:31,976 DEBUG FW with id: 1 is unique!
2020-11-13 13:56:31,987 DEBUG Created/updated Launch with launch_id: 1
2020-11-13 13:56:32,006 DEBUG RUNNING FW with id: 1
launchpad-error.log: empty
queue_launcher-error.log: empty
rocket_launcher-debug.log:
2020-11-13 13:57:34,315 INFO Task completed: {{atomate.vasp.firetasks.run_calc.RunVaspCustodian}}
2020-11-13 13:57:34,320 INFO Task started: {{atomate.common.firetasks.glue_tasks.PassCalcLocs}}.
2020-11-13 13:57:34,320 INFO Task completed: {{atomate.common.firetasks.glue_tasks.PassCalcLocs}}
2020-11-13 13:57:34,325 INFO Task started: {{atomate.vasp.firetasks.parse_outputs.VaspToDb}}.
2020-11-13 13:57:47,157 INFO Rocket finished
And I double checked OUTCAR, it indeed finished with timing information.
As you suggested, I typed “lpad webgui” command and I’m not sure where to find error information. What I got is as shown below:
Could it be due to the wrong config files? Below are my configs:
my_fworker.yaml:
category: ‘’
query: ‘{}’
env:
db_file: /global/homes/w/wygong/wf/config/db.json
vasp_cmd: ‘srun -n 32 -c 2 --cpu_bind=cores vasp_std’
gamma_vasp_cmd: ‘srun -n 32 -c 2 --cpu_bind=cores vasp_gam’
scratch_dir: /global/cscratch1/sd/wygong/
incar_update:
my_launchpad.yaml:
host: mongodb07.NERSC.gov
port: 27017
name:
username:
password:
logdir: /global/homes/w/wygong/wf/logs
Istrm_lvl: DEBUG
user_indices: []
wf_user_indices: []
my_qadaptor.yaml:
_fw_name: CommonAdapter
_fw_q_type: SLURM
_fw_template_file: /global/homes/w/wygong/.conda/envs/workflow/config/SLURM_VASP_template
time: 00:30:00
partition: regular
nodes: 1
system: haswell
job_name: test_job
account: null
pre_rocket: module load vasp
rocket_launch: rlaunch -w /global/homes/w/wygong/.conda/envs/workflow/config/my_fworker.yaml singleshot
post_rocket: null
Thanks!
Weiyi
