Basic questions of new leaners
As a new learner, I want to ask some basic questions. Could you please show me the detailed order of band structure calculation.
For example, as for band structure of mp-149, now I only know the first two steps should be structure optimization and static calculation, what about next steps?
And I could not understand the process of uniform,as it seemingly does not exist in vasp mannual, so what is the aim and effect of this process?
A reply would be highly appreciated. I really hope for a detailed reply so that I can follow your calculation which would definitely be beneficial for my understanding and learning.
Hi @laura_zhou,
The static calculation gives a high-quality self-consistent charge density as its output. This charge density is then used as the input for a non-self-consistent band structure calculation, which is a calculation with k-points chosen specifically along high-symmetry points in Brillouin zone.
This page in the VASP manual might help you: https://cms.mpi.univie.ac.at/vasp/vasp/Accurate_DOS_Band_structure_calculations.html
Therefore, the process here is optimize structure → static calculation → band structure to obtain a band structure plot.
The uniform calculation is very similar to the band structure calculation except it samples reciprocal space uniformly (a uniform k-point grid, at a high density of k-points), this is used to calculate the density of states.
The process here is then optimize structure → static calculation → uniform calculation to obtain a density of states plot.
Hope this helps!
Matt
Thank you so much for your detailed reply. I feel very pleased and moved for your kind help~
