Hi @alex
I want to run batch optimization. The functionality of batch optimization is currently not working. Please find the relevant code which is simply finding a minima of Rosenbrock test function, batch_size of anything >1 causes FW to go to sleep loop:
from fireworks import FireTaskBase, Firework, FWAction, LaunchPad, Workflow
from fireworks.core.rocket_launcher import rapidfire
from fireworks.utilities.fw_utilities import explicit_serialize
from rocketsled import MissionControl, OptTask
import numpy as np
# Setting up the FireWorks LaunchPad
launchpad = LaunchPad(name="rsled")
opt_label = "opt_default"
db_info = {"launchpad": launchpad, "opt_label": opt_label}
x_dim = [(-5.0, 5.0), (-5.0, 5.0)]
@explicit_serialize
class ROSENBROCKTask(FireTaskBase):
_fw_name = "ROSENBROCKTask"
def run_task(self, fw_spec):
x = fw_spec["_x"]
y = (1 - x[0])** 2 + 100*(x[1] - x[0] ** 2) ** 2
return FWAction(update_spec={"_y": y})
def wf_creator_ROSENBROCK(x):
spec = {"_x": x}
# ObjectiveFuncTask writes _y field to the spec internally.
firework1 = Firework([ROSENBROCKTask(), OptTask(**db_info)], spec=spec)
return Workflow([firework1])
def execute(n_evaluation, predictor_Selected, acquisition_function):
mc = MissionControl(**db_info)
launchpad.reset(password=date_, require_password=True)
mc.reset(hard=True)
mc.configure(wf_creator=wf_creator_ROSENBROCK, dimensions=x_dim, acq=acquisition_function,
predictor=predictor_Selected,batch_size=2)
launchpad.add_wf(wf_creator_ROSENBROCK([a, b]))
rapidfire(launchpad, nlaunches=n_evaluation, sleep_time=0)
mc.results()
if __name__ == "__main__":
date_='2021-11-28'
a = np.random.uniform(-5,5)
b = np.random.uniform(-5,5)
predictor_Selected = 'GaussianProcessRegressor'
acquisition_function = 'lcb'
n_evaluation = 100
My objective is to use the batch optimization to run several parallel experiments based on suggestions and implement other heuristic such as Krigging Believe and compare the results.
Abdul Wahab
