I am trying to fix one end of a beam and then apply a load on the other end (Cantilever). I have a problem that whenever i run equlibration, the temp never goes to 300! Also in the deformation I have the same problem.
Is there a possibility to use S S S ?
I attached the equlibration script. Thanks
boundary s s p
atom_style atomic
----------------------- ATOM DEFINITION ----------------------------
variable latparam equal 5.431
variable L_x equal 50
variable L_y equal 10
variable L_z equal 10
lattice diamond {latparam}
region whole block 0 {L_x} 0 {L_y} 0 {L_z}
create_box 1 whole
region Si_fixed block 0 {L_y} 0 {L_y} 0 {L_z} units box
region Si_middle block {L_y} 40 0 {L_y} 0 {L_z} units box
region Si_load block 40 {L_x} 0 {L_y} 0 ${L_z} units box
region Si_total union 3 Si_fixed Si_middle Si_load
lattice diamond ${latparam} orient x 1 0 0 orient y 0 1 0 orient z 0 0 1
create_atoms 1 region Si_total
------------------------ FORCE FIELDS ------------------------------
pair_style meam
pair_coeff * * library.meam Si Ni.meam Si
neighbor 2.0 bin
------------------------- SETTINGS ---------------------------------
compute csym all centro/atom 4
compute eng all pe/atom
------------------------- GROUPS ---------------------------------
group Gr_Si_fixed region Si_fixed
group Gr_Si_middle region Si_middle
group Gr_Si_load region Si_load
group Gr_Si_mobile union Gr_Si_load Gr_Si_middle
group Gr_Si_total region Si_total
------------------------------Equilibration---------------------
EQUILIBRATION
reset_timestep 0
timestep 0.001
velocity Gr_Si_mobile create 300 12345 mom yes rot no
fix 1 Gr_Si_mobile nvt temp 300.0 300.0 0.1
Set thermo output
thermo 1000
thermo_style custom step lx ly lz press pxx pyy pzz pe temp
Run for at least 10 picosecond (assuming 1 fs timestep)
run 30000
unfix 1
undump 1
Mohamed
