Beginner in the Field of MD
I am just starting my PhD, and my topic is “Molecular dynamics investigation of pressure-dependent interfacial rheology in a gas-saturated crude oil-brine system with eco-compatible demulsifier.” I have never used MD before now. I know the physics behind my research, but I don’t know where to begin with using MD to achieve this work. I will need all the help to get started with this work.
Thanks in anticipation
Sincerely
Mahmud
Since MD is the topic of your PhD, there surely must be someone in your department (ideally, one of your supervisor, advisor, or co-workers) which has this expertise. You definitely do not want to outsource this skill in a forum: no one has the time and dedication needed to provide university-grade higher education to online students.
Good luck for your research. If you have problems using LAMMPS:
  1. read the documentation for the specific command
  2. study the examples shipped with the source code
  3. search the forum, there is a lot of wisdom here
  4. last resort: post a new question when you are absolutely sure no one has asked that before.
And, of course, Please Read This First: Guidelines and Suggestions for posting LAMMPS questions
