When loading a bunch of files into ovito-python by ‘import_file’, it’s possible to see the number of data files imported:
pipeline = import_file("...")
nframes = pipeline.source.num_frames
When using this pipeline within the loop over the ‘num_frames’, how can I know which specific file will be processed in each loop iteration. What I need is something like
for id in range(1,nframes+1):
filename = pipeline.source.filename[id] # <-- hypothetical code
How can I achieve this?
Thanks!
