Dear all lammps users,
I have a sphere of triangulation mesh, each vertex represents a bead, the edge
represents a bond connecting two beads. Now I want to add bending potential into
this structure. From the literature, this can be done by adding adding a bending potential
between the two normal vectors of two neighboring triangles, i.e.
U_bend = k ( 1- cos \theta_ij ),
where \theta_ij is the angle between the two normal vectors of adjacent triangles i and j.
My problem is that how to do this in lammps? Is there any built-in potential to do this?
If not, what shall I do to add this feature into lammps?
Thanks in advance!!
Aiqun
edge
into
bending potential
triangles i and j.
depends on what other potentials are involved.
in principle, each pair of triangles could be seen as a dihedral
interaction. only for dihedrals the angle is defined through the angle
between the two planes, not the normals.
the manual explains how to modify LAMMPS with additional potentials
and features.
