I am having some issues implementing the berendsen barostat in my glycine water system. My initial attempt consisted of the following fixes
fix 1 all nve
fix 2 all langevin 270.0 270.0 2000.0 699483
fix 3 all shake 0.000001 20 100000 b 1 3 5 a 4 #constrain N-H C-H and O-H
fix 4 all press/berendsen iso 1.0 1.0 1000.0
However, within five time steps I actually got a negative volume and quickly a pppm atom out of range error popped up. The volume of the system doubled between steps 1 and 2. Clearly the dynamcs were very bad.
I did some digging on the email list, and found discussions where people said to first equilibrate in NVT. So I tried the following
fix 1 all nve
run 10000
run 10000
Now I know 10000 isn’t long enough from a true equilibration, but I think it should be long enough to get out and kinks that could produce instability numerics. However, again this blew up within 5 to 10 steps as before.
I then tried
fix 1 all nve
fix 4 all press/berendsen iso 1.0 1.0 1000000.0
Now this produces a stable numerical integration. However, from the examples I could find on the mailing list, my own experience, and the lammps doc example, that seems like an outrageously large pdamp. However, the volume of the system is still changing by 50A^3 between time steps, which is reasonable. Could anyone comment here? If I think about my knowledge of the berendsen algorithm, it looks something like
mu = 1 -(dt/tau)(ptarget-pressure)/nktv2p
mu = mu**(1.0d0/3.0d0)
box = boxmu
We would then also scale the particle coordinates. Am I incorrect to interpret the lammps pdamp parameter as tau in the above equation?
Also of note, fix 1 all npt temp 270.0 270.0 100.0 iso 1.0 1.0 1000.0 produces a stable numerical integration.
Input file and data file are attached.
glycine-water.in (2.62 KB)
data.glycine-test (801 KB)
