I am intending to screen through 1004 chemical systems containing aluminum (e.g., Al-Li-Zn, Al-Mg-Cu…), and then retrieve the ElasticityDocs for all the qhull_entries within each chemical system. I am planning to carry out this search with the new mp-api package.
I’ve sent a request to [email protected], but have not heard back yet.
Here is a code snippet that I intend to use. Could you please tell me the best practices and time to carry out this search? (e.g., pause time between each API call; aggregate search instead of for-loops; should I carry out the search during midnight? …)
import time
from mp_api import MPRester
from mp_api.core.client import MPRestError
from pymatgen.analysis.phase_diagram import PhaseDiagram
# read the API key from a txt file
with open("api_key.txt") as f:
API_KEY = f.read()
def query_one_chemsys(chemsys: str) -> dict:
"""Helper function to carry out the query for one chemsys"""
chemsys_lst = sorted(chemsys.split("-"))
# get all ComputedStructureEntry within the given chemsys
with MPRester(api_key=API_KEY) as mpr:
phase_diagram_entries = mpr.get_entries_in_chemsys(chemsys_lst)
# check if no entries has been returned
if len(phase_diagram_entries) == 0:
raise MPRestError("No valid entries")
phase_diagram = PhaseDiagram(entries=phase_diagram_entries)
# check if the dimensionality of the retrieved phase diagram matches the input chemsys
if phase_diagram.dim != len(chemsys_lst):
raise MPRestError("Entries dimensionality mismatch")
# get the most stable phase entries
most_stable_entries = phase_diagram.qhull_entries
# get the mp-id for each entry in most_stable_entries
mp_ids = [entry.entry_id for entry in most_stable_entries]
# retrieve the elasticity doc for each mp-id
material_elasticity_docs = []
for mp_id in mp_ids:
try:
material = mpr.elasticity.get_data_by_id(mp_id)
material_elasticity_docs.append(material)
except MPRestError:
material_elasticity_docs.append(None)
# store the elasticity data within each ComputedStructureEntry in a dictionary format
mp_docs_to_store: list = []
for entry, elasticity_doc in zip(most_stable_entries, material_elasticity_docs):
entry_dict = entry.as_dict()
entry_dict["data"]["elasticity"] = elasticity_doc.dict()["elasticity"] if elasticity_doc is not None else None
mp_docs_to_store.append(entry_dict)
return {f"{chemsys}": mp_docs_to_store}
chemsys_to_screen: list = ["Al-Li-Zn", "Al-Mg-Cu"]
screening_results = []
chemsys_with_errors = []
for chemsys in chemsys_to_screen:
try:
single_chemsys_result = query_one_chemsys(chemsys)
screening_results.append(single_chemsys_result)
except MPRestError:
chemsys_with_errors.append(chemsys)
time.sleep(10)
Best
Peiwen
