Hello!
I am interested in straining a crystal system (+/-25 kbar) and calculating the dielectric tensor for a list of materials. I have the code in place to calculate the dielectric tensor using the ‘wf_dielectric_constant’ workflow and would like to add a power-up or use an alternative method to strain the crystal and then perform the calculation.
Here is an example of a test code I’ve used in the past to run a dielectric constant wf with some lines commented out for using a power-up to change the INCAR parameters.
#!/usr/bin/env python3
import numpy as np
from pymatgen import MPRester
from fireworks import LaunchPad
from atomate.vasp.workflows.presets.core import wf_dielectric_constant
from atomate.vasp.powerups import add_modify_incar
# Get the structure from the Materials Project
with MPRester() as mpr:
struct = mpr.get_structure_by_material_id('mp-4651')
# Create the workflow
workflow = wf_dielectric_constant(struct)
#print("original")
#print(workflow.fws[0].tasks)
#modified_wf = add_modify_incar(workflow, modify_incar_params={'incar_update': {'NCORE': 28}})#,
#fw_name_constraint='optimization')
#print("modified")
#print(modified_wf.fws[0].tasks)
# Create the launchpad and add our workflow
launchpad = LaunchPad.auto_load()
launchpad.add_wf(workflow)
