Dear all lammps users,
I’m simulating a BN system with dimensions 5*5nm. Below is my input file and I’m using BNC.tersoff potential for this system.
I’m facing a problem, while doing tensile test, BN sheet is not expanding, while boundary lines are expanding.
I’ve tried the same input file for Graphene, (similar structure to BN ), It is working fine.
I suspect that the problem in BN is having two different atoms of different mass.
Please throw some light on causes of this error.
I would be grateful to you all
Input file :
echo both
atom_style full
newton on
read_data bn.layer
pair_style tersoff
pair_coeff * * BNC.tersoff B N
neighbor 2.0 bin
neigh_modify delay 1
timestep 0.0005
fix 1 all npt temp 300.0 300.0 0.05 y 0 0 0.05
thermo 200
compute 1 all stress/atom NULL
compute 2 all pe/atom pair bond
compute 3 all reduce sum c_1[1] c_1[2] c_1[3]
thermo_style custom step temp pe ke etotal press lx ly lz
run 60000
unfix 1
fix 1 all nvt temp 300 300 0.05
fix 2 all ave/atom 1 1000 1000 c_1[1] c_1[2] c_1[3] c_2 fx fy fz
fix 3 all ave/time 1 1000 1000 c_thermo_press[2] file stress.all
dump 1 all custom 1000 dump.new.* id type x y z vx vy vz c_1[1] c_1[2] c_1[3] c_2 f_2[1] f_2[2] f_2[3] f_2[4] f_2[5] f_2[6] f_2[7]
dump 2 all xyz 1000 dump.graphene.*.xyz
variable tmp equal “lx”
variable L0 equal {tmp}
print "Initial Length, L0: {L0}"
variable srate equal 1.0e9
variable srate1 equal “v_srate/1.0e12”
fix 4 all deform 1 x erate ${srate1} units box remap x
variable strain equal “(lx-v_L0)/v_L0”
variable p0 equal “v_strain”
variable p1 equal “-(pxx)/10000”
variable p2 equal “-(pyy)/10000”
fix 5 all print 1000 "{p0} {p1} ${p2} " file strain.txt screen no
thermo_style custom step temp v_strain v_p1 v_p2 press
run 600000
echo both
Khannan Krishna
Research scholar,
Department of Material science,
university of calicut.
