I was trying to run a simulation using files from a DL_POLY simulation. Basically I converted the DL_POLY CONFIG file to a PDB file. Then with this PDB file and CHARMM force field file the LAMMPS input files was generated using ch2lmp. However, while running the equilibration, I found that the initial energy and temperature of the system was extremely high, and I have to use very small time step to get the system equilibrated. This does not look normal because the initial configuration I was using has already been equilibrated.
While looking at the ‘log.lammps’ file, I could find the following warnings.
WARNING: Inconsistent image flags (…/domain.cpp:594)
WARNING: Bond/angle/dihedral extent > half of periodic box length (…/domain.cpp:667)
Combining with the fact that in the initial stage of my equilibration the bond energy was very high, I think this might have something to do with improper bonding between atoms. After doing some search in the archive of this mailing list, I guess the warning message arises from the wrong image information in my data file. Since my input data file was generated from ch2lmp, no information about the image was given. Therefore the image number of all atoms would be initiated as zero at the beginning of the simulation, resulting in very long bond connecting two atoms in the same molecule if they were distributed on the two sides of the box, respectively.
So I’m wondering if there is anyway that I could resolve this issue by simply modifying my input parameters, or I must add image information to the data file?
I’ve also pasted my input file here, and thank you very much for your help.
Shule
Created by charmm2lammps v1.8.1 on Thu Aug 29 15:42:35 CDT 2013
units real
neighbor 2.0 bin
neigh_modify every 1
atom_style full
bond_style harmonic
angle_style harmonic
dihedral_style charmm
pair_style lj/cut/coul/long 14.0
pair_modify mix arithmetic
kspace_style ewald 1e-5
read_data cyl10-1.2_assign.data
group C1 type 15
fix 3 C1 setforce 0.0 0.0 0.0
fix 1 all nvt temp 298.0 298.0 100
thermo 100
thermo_style multi
timestep 0.001
restart 100 cyl10-1.2_assign.restart1 cyl10-1.2_assign.restart2
dump 1000 all custom 100 cyl10-1.2.trj id type q x y z vx vy vz fx fy fz
run 1000000
