I’m am trying to learn how to use the rerun command. I have an XYZ data file (generated from VMD of a previous simulation) with the coordinated wrapped into the PBC box. When I run the input script below, I get “bond missing” error. Any ideas for what I’m doing wrong?
Thanks for the help,
Stacey
I suppose we should try to run a simulation?
units real
atom_style full
boundary p p f
read_data Slab_1.data
pair_style lj/cut/coul/cut 10.0 12.0
bond_style harmonic
angle_style harmonic
dihedral_style fourier
special_bonds amber
you must not wrap bonds.
you should not use .xyz files for periodic systems, as the .xyz file does not contain simulation box information.
Thanks Axel
I wrote out a lammpstrj file with VMD on the unwrapped coordinates and changed the rerun command to:
rerun input.lammpstrj dump x y z box no wrapped no
Thank did the trick.
Thanks again,
Stacey
