Bond atoms 16825 16826 missing
I tried to build an ordered water molecule structure using the replicate command, but I encountered a “bond atom missing” error right at the beginning. Below is my input script.
atom_style full
boundary p p f
read_data 1H2O1
replicate 26 26 26
pair_style lj/cut/tip4p/cut 1 2 1 1 0.1546 12
bond_style harmonic
angle_style harmonic
pair_coeff 1 1 0.008039 3.1589 # O-O
pair_coeff 2 2 0.0 0.0 # H-H
pair_coeff 1 2 0.0 0.0 # O-H
pair_modify tail yes
bond_coeff 1 43.36 0.9572 # O-H
angle_coeff 1 4.336 104.52 # H-O-H
group water type 1 2
neighbor 3.0 bin
velocity all create 300 12345 dist gaussian
#fix 1 water shake 1.0e-4 100 0 b 1 a 1
variable massAll equal mass(all)/6.022e23
variable volCm3 equal vol*1.0e-24
variable density_sys equal v_massAll/v_volCm3
thermo 1000
thermo_style custom step temp vol etotal pe ke epair ecoul lx ly lz v_density_sys cpuremain
thermo_modify flush yes
fix nvt all nvt temp 300 300 200.0
timestep 1.0
run 150000
write_data 26by26by26_H2O1.data
Step Temp Volume TotEng PotEng KinEng E_pair E_coul Lx Ly Lz v_density_sys CPULeft
0 300 1058712.9 128807.35 126762.7 2044.6499 126762.7 127272.04 101.92 101.92 101.92 0.49663825 0
ERROR on proc 0: Bond atoms 16825 16826 missing on proc 0 at step 1 (…/ntopo_bond_all.cpp:63)
Last command: run 150000
Please have a good look at this post and learn from it what kind of help and advice you can expect from this forum and also follow the given suggestions in what information to provide and how to present your inquiries.
Your post is in conflict with several of those guidelines starting with the fact, that you don’t even ask a question.
