Hello everyone
I’m simulating water droplet on a copper flat surface
water molecules were created externally via a Fortran code
I’m receiving this message at the beginning of simulation
Step Temp E_pair E_ mol TotEng Press
0 100 6.6574955e+15 0 6.6574955e+15 8.1928902e+15
ERROR on proc 0: Bond atoms 46 47 missing on proc 0 at step 1 (…/ntopo_bond_all.cpp:63)
the values of pressure and energies are very high
any one can help solving this problem…. Thanks in advance
here is the simulation script
# Program lammps
units real
atom_style full
read_data droplet3.txt
include forcefield.SPC
lattice fcc 3.597
region 1 block 0. 100. 0. 10. 0. 100.
create_atoms 3 region 1
variable Text equal 100.0
variable Pext equal 1.0
velocity all create ${Text} 1234
neighbor 2.0 bin
timestep .02
fix constrain all shake 1.0e-4 100 0 b 1 a 1
fix integrate all nvt temp {Text} {Text} 100.0
thermo 1
dump 1 all atom 1 dump.flow
run 10000
