Dear all
I am attempting to simulate water adsorption on MOF and have encountered the following error:
Bond atoms 3926 3928 missing on proc 9 at step 1768
lammps version : LAMMPS (7 Feb 2024 - Update 1)
In my simulation, I first read the MOF structure and create water atoms inside the box.
Here I tried flexible water model using spc/fw water and mSPC/fw (DOI: 10.1039/c6cp06770k), one uses harmonic bonds and another one uses morse bonds for bond streching.
For the pure water, both 2 water models can work.
However, the adsorption simulation can run smoothly with harmonic bond, but it always shows ‘bond atom missing’ with morse bonds.
I read from here [lammps-users] ERROR on proc: Bond atoms missing and here Problem with bond or angle atom missing that the possible reason might be
- reneighboring far too infrequently: I reneighbor every 1 step.
- large time step: I tried 0.1 fs and 0.25 fs, they works for harmonic bond but not morse bond.
- some atoms overlap: I tried
delete_atoms overlap 0.5
It will be highly appreciated if someone could give me some suggestion about how to handle this.
Warnings I’ve got:
1. WARNING: Triclinic box skew is large. LAMMPS will run inefficiently.
As I am doing only NVT and NVE simulation, the box will not change, so this will not cause big problem.
2. WARNING: Neighbor exclusions used with KSpace solver may give inconsistent Coulombic energies
This may be caused by using
neigh_modify exclude group frame frame check no
But this is to exclude the intra framework interactions as we consider it rigid.
3. WARNING: Ignoring 'compress yes' for molecular system
‘compress yes’ is not done for molecular systems (see the atom_style command), regardless of the compress setting. So this warning can be no trouble.
Below are my input files.
data.MIL-101-primitive (1.4 MB)
FlexibleH2O.txt (370 Bytes)
in.mspcfw.lammps (4.4 KB)
in.spcfw.lammps (4.5 KB)
JIANG
