I’m studying a bulk containing polymer chains (A), waters, and ions, in All-Atom MD using charmmff and periodic in 3 dimensions.
I already ran this system for a few ns successfully and I have values for “Image Flags” in my datafile.
In the second step, I added the second polymer (B) to the previous system using “read_data add append…”, and also it runs perfectly without any problem.
Then I used the “fix bond/create” command to create bonds between polymers (A and B). Everything goes well, except I get the famous warning “Inconsistent image flags”.
I checked the dump and it seems there are a few bonds that are created between polymer B and Images of polymer A, near the edge of the box.
Is there any solution to prevent such bond creations?
P.S. I’m working with the stable version of lammps (29Sep2021), and I work with write_data and read_data to continue my dynamics in each step.
