I have the following question.
I am trying to use this script to create bonds between particles type 3 and with a cut-off of 5 and analyze them with OVITO.
create_bonds_modifier = CreateBondsModifier(mode=CreateBondsModifier.Mode.Pairwise)
create_bonds_modifier.set_pairwise_cutoff(3, 3, 5)
bonding.modifiers.append(create_bonds_modifier)
pipeline.modifiers.append(BondAnalysisModifier(bins = 500))
And when I export the data I get a histogram that goes from 0 to 4. Is there some maximum cutoff value that is included in the CreateBondsModifier and should be modified?
In the documentation, it is said “Maximum bond length at which the bond length distribution gets truncated.” and the Default value is 4.0.
However, when I use the application , I see that bonds are formed that meet the condition.
Any comments that can help me understand why I am not being able to make the bonds?
