I wanted to create a polymer where the backbone monomer has a sidechain that also grows. Earlier, I used a huge backbone where I explicitly added the sidechain. However, is there an easier way to do this? I tried the following way, but I am getting No terminator for polymer ‘poly’ error.
(* EMC: Script *)
(* Created by emc.pl v3.5.3, June 26, 2018
on Wed Jun 27 19:17:46 CEST 2018 *)
(* define variables *)
variables = {
seed -> -1,
ntotal -> 1000,
fshape -> 1,
output -> "polymer",
field -> "pcff/pcff",
location -> $root+"field/",
nav -> 0.6022141179,
temperature -> 300,
radius -> 5,
nrelax -> 100,
weight_nonbond -> 0.0001,
weight_bond -> 0.0001,
weight_focus -> 1,
cutoff -> 9.5,
charge_cutoff -> 9.5,
kappa -> 4,
density1 -> 0.85,
f_poly -> 1,
chem_bb -> "*C(*C)C*",
chem_sc -> "*CCC*",
chem_tbb -> "*C",
chem_tsc -> "*C"
output = {
debug -> false,
exit -> true,
info -> true,
warning -> true
(* define force field *)
field = {
mode -> cff,
name -> {location+field+".frc", location+field+"_templates.dat"}
(* define groups *)
groups = {
group -> {id -> bb, depth -> 8, chemistry -> chem_bb,
connects -> {
{source -> $end1, destination -> {bb, $end3}},
{source -> $end1, destination -> {tbb, $end1}},
{source -> $end3, destination -> {tbb, $end1}},
{source -> $end3, destination -> {bb, $end1}},
{source -> $end2, destination -> {sc, $end1}}
group -> {id -> sc, depth -> 8, chemistry -> chem_sc,
connects -> {
{source -> $end1, destination -> {bb, $end2}},
{source -> $end2, destination -> {sc, $end1}},
{source -> $end2, destination -> {tsc, $end1}}
group -> {id -> tbb, depth -> 8, chemistry -> chem_tbb,
connects -> {
{source -> $end1, destination -> {bb, $end1}},
group -> {id -> tsc, depth -> 8, chemistry -> chem_tsc,
connects -> {
{source -> $end1, destination -> {sc, $end2}},
field = {
mode -> apply,
check -> true,
debug -> false
simulation = {
types -> {
cff -> {
pair -> {active -> true, mode -> repulsive, cutoff -> cutoff}
(* determine simulation sizing *)
variables = {
(* lengths *)
lg_bb -> nsites(bb),
lg_sc -> nsites(sc),
lg_tbb -> nsites(tbb),
lg_tsc -> nsites(tsc),
norm_poly -> 100,
l_poly -> (10*lg_bb+10*lg_sc+2*lg_tbb+1*lg_tsc)*100/norm_poly,
(* masses *)
mg_bb -> mass(bb),
mg_sc -> mass(sc),
mg_tbb -> mass(tbb),
mg_tsc -> mass(tsc),
norm_poly -> 100,
m_poly -> (10*mg_bb+10*mg_sc+2*mg_tbb+1*mg_tsc)*100/norm_poly,
(* mol fractions *)
f_poly -> f_poly*l_poly,
(* normalization *)
norm -> f_poly,
f_poly -> f_poly/norm,
(* sizing *)
n_poly -> int(f_poly*ntotal/l_poly+0.5),
(* system sizing *)
ntotal -> 0,
mtotal -> 0
(* define interactions *)
simulation = {
units -> {
permittivity -> 1,
seed -> seed
types -> {
coulomb -> {
pair -> {active -> true, cutoff -> charge_cutoff}
(* clusters phase 1 *)
clusters = {
polymer -> {
id -> poly, system -> main, type -> alternate,
n -> int(100*n_poly/norm_poly+0.5),
groups -> {bb, sc, tbb, tsc},
weights -> {1, 1, 1, 1},
nrepeat -> {10, 100, 2, 10}
(* build phase 1 *)
variables = {
nphase1 -> ntotal()-ntotal,
mphase1 -> mtotal()-mtotal,
vphase1 -> mphase1/nav/density1,
lbox -> (vphase1/fshape)^(1/3),
lphase1 -> fshape*lbox,
lxx -> lphase1,
lyy -> lbox,
lzz -> lbox,
lzy -> 0,
lzx -> 0,
lyx -> 0,
lphase -> lphase1,
ntotal -> nphase1,
mtotal -> mphase1,
vtotal -> vphase1
field = {
mode -> apply,
check -> true,
debug -> false
simulation = {
types -> {
cff -> {
build = {
system -> {
id -> main,
geometry -> {xx -> lxx, yy -> lyy, zz -> lzz,
zy -> lzy, zx -> lzx, yx -> lyx},
temperature -> temperature,
flag -> {charge -> true, map -> true, pbc -> true}
select -> {
progress -> list,
frequency -> 1,
name -> "error",
cluster -> {poly},
relax -> {ncycles -> nrelax, radius -> radius},
grow -> {
method -> energetic,
check -> all,
nbonded -> 20,
ntrials -> 20,
niterations -> 1000,
weight -> {
bonded -> weight_bond, nonbonded -> weight_nonbond,
focus -> weight_focus}
force = {style -> none, message -> nkt};
force = {style -> init, message -> nkt};
(* LAMMPS profile variables *)
variables = {
nl_poly -> nclusters(clusters -> poly)
(* storage *)
put = {name -> output, compress -> true};
pdb = {name -> output, forcefield -> cff, detect -> false,
hexadecimal -> false, unwrap -> true, pbc -> true,
atom -> index, residue -> index, segment -> index,
vdw -> false, cut -> false, fixed -> true, rigid -> true,
connectivity -> false, parameters -> false};
lammps = {name -> output, mode -> put, forcefield -> cff,
parameters -> true, types -> false, unwrap -> true,
charges -> true, ewald -> true};
