I simulated nanoindentation on a small slab with an indenter which displaces following the direction Y, the EPS method for peridynamics is used. Moreover, I used boundaries conditions P S P to have periodicity in the direction X and Z. Furthermore, I fixed the two last layers. But, after adding this boundaries conditions, I observed a change in my atomic distribution on the extremities of slab. Indeed,the two lowest layers don´t move as they are fixed but two atoms on the right side are lost. Besides, the three topest layers lost 4 atoms on the left side. Do you have any explanation ? Because, I tried those boundary conditions with MD and it works.
Thank you for your consideration
Simon
question.docx (293 KB)
