buck/coul potential metal oxide minimization
Dear Sir or Madam,
I have been trying to use buck/coul potential to find the bond length of metal oxide. The parameters are found in literature. My input is following and data file is attached:
---------- Initialize Simulation ---------------------
clear
atom_style charge
---------- Create Atoms ---------------------
read_data data_new_RS.MO
mass 1 24.304 #Mg
mass 2 58.933 #Co
mass 3 63.546 #Cu
mass 4 58.693 #Ni
mass 5 65.38 #Zn
mass 6 16.0 #O
---------- Define Interatomic Potential ---------------------
pair_style buck/coul/long 10.0 10.0
pair_coeff * * 0.0 0.1 0.0
pair_coeff 1 6 821.6 0.3242 0.0
pair_coeff 2 6 696.3 0.3362 0.0
pair_coeff 3 6 3860.6 0.2427 0.0
pair_coeff 4 6 683.5 0.3332 0.0
pair_coeff 5 6 499.6 0.3595 0.0
pair_coeff 6 6 22764.0 0.1490 43.0
kspace_style ewald 1.e-6
---------- Run Minimization ---------------------
reset_timestep 0
fix 1 all box/relax aniso 0.0 vmax 0.001
thermo 100
thermo_style custom step pe lx ly lz press pxx pyy pzz
min_style cg
minimize 1e-10 1e-10 5000 10000
The results are
Step PotEng Lx Ly Lz Press Pxx Pyy Pzz c_
0 -20552.037 20.7 20.7 20.7 7907.1889 7907.1889 7907.1889 7907.1889
100 -20562.403 20.723425 20.723557 20.73678 786.91633 1136.4082 1140.623 83.717806
200 -20564.346 20.728921 20.72917 20.737892 401.429 639.02306 650.0531 -84.789163
300 -20565.977 20.734838 20.735478 20.739051 159.0794 274.43534 281.81439 -79.011541
376 -20568.192 20.750291 20.751315 20.747824 94.9827 -17.705675 174.78765 127.86612
Loop time of 14.1734 on 4 procs for 376 steps with 1000 atoms
It can be seen that the pressure is really high after minimization is converged. I have no idea why this happened so would you please help check this and let me know where I got wrong? Thank you very much!
Siming
data_new_RS.MO (46 KB)
Dear Sir or Madam,
The results are
i disagree with your assessment. the final pressure is not very high and it has already been reduced significantly from its initial value (and the box expanded correspondingly). you have to take into account that solids are not very compressible and thus even small changes of volume will result in very large changes in pressure.
