I think I found a bug in the calculation of forces for the angle_style cosine/periodic when the multiplicity is one. In such a case (as a result of the fact that the loop at lines 133-137 is not entered), computed forces are only half of what they should be.
I suggest to modify line 120
un = 1.0;
into
if(m==1){un=2.0;}else{un=1.0;}
All code lines refer to the latest stable version (2Aug2023).
When I input the posted potential formula into angle style lepton and use the angle_write command to compare the potential energy and force for the case n=1 and n=2 to that of angle style cosine/periodic, the potential energy and forces agree. Here is the input I am using:
Correction: the angle_write command is not a sufficient test because it only uses the potential energy from the Angle::single() function and then generates the force through numerical differentiation.
Here is a proper test that, again, compares cosine/periodic against lepton and this one does show the factor 2 difference for the multiplicity = 1 case, so your suggested bugfix is required.
atom_style molecular
units real
region box block -10 10 -10 10 -10 10
create_box 1 box angle/types 1 extra/angle/per/atom 2 extra/special/per/atom 4
mass 1 1.0
create_atoms 1 single 1.0 0.0 0.0
create_atoms 1 single 0.0 0.0 0.0
create_atoms 1 single -1.0 0.0 0.0
create_bonds single/angle 1 1 2 3
pair_style zero 1.0
pair_coeff 1 1
timestep 1.0
group move id 1
fix 1 move move rotate 0.0 0.0 0.0 0.0 0.0 1.0 100.0
thermo_style custom step pe eangle fmax
thermo 10
angle_style lepton
angle_coeff 1 0 "2.0*C*(1-cos(theta)); C=75.0"
dump 1 all custom 10 lepton-n=1.lammpstrj id x y z fx fy fz
run 100 post no
undump 1
reset_timestep 0
angle_coeff 1 0 "0.5*C*(1-cos(2*theta)); C=75.0"
dump 1 all custom 10 lepton-n=2.lammpstrj id x y z fx fy fz
run 100 post no
undump 1
reset_timestep 0
angle_coeff 1 75 1 1
dump 1 all custom 10 cosine-n=1.lammpstrj id x y z fx fy fz
run 100 post no
undump 1
reset_timestep 0
angle_coeff 1 75 1 2
dump 1 all custom 10 cosine-n=2.lammpstrj id x y z fx fy fz
run 100 post no
undump 1
reset_timestep 0
