Hello everyone,
Now I want to bulild LAMMPS with CMAKE. I followed the manual 3.1. Build LAMMPS with CMake — LAMMPS documentation.
The command line:
cd lammps # change to the LAMMPS distribution directory
mkdir build; cd build # create and use a build directory
cmake …/cmake # configuration reading CMake scripts from …/cmake
cmake --build . # compilation (or type “make”)
The compilation is done but when I run script with command line: lmp -in test.in.
Linux terminal displays: Command ‘lmp’ not found.
Could you tell me the reason and how to fix that?
Thank you very much!
