Building a shared library with cmake
Folks, this seems very silly, but I cannot seem to build a shared library with cmake, I seem to be able to build the static library, but no matter what I do, the shared library will not be built.
Steps taken (on a Kubuntu 18.04 workstation):
mkdir build_shared && cd build_shared
cmake -BUILD_SHARED_LIBS=yes -DCMAKE_INSTALL_PREFIX=/apps/LAMMPS/22Aug18 …/cmake/
After this is completed, I can run find . | grep *.so which returns nothing.
This seems very silly, but shouldn’t this work? What am I missing. I have read the various web sites and I cannot find what I may be missing.
Thank you for your help.
Silly question: did you remember to CD into the build directories before executing cmake ?
Hi Ethan,
you need to add -D BUILD_LIB=yes in addition to -D BUILD_SHARED_LIBS=yes
cmake -D BUILD_LIB=yes -D BUILD_SHARED_LIBS=yes -D CMAKE_INSTALL_PREFIX=/apps/LAMMPS/22Aug18 …/cmake/
Richard
Micholas, Thanks for asking the obvious question, but fortunately, I had not forgotten to do that!
Richard, I swear I tried that before and it hadn’t worked. But, I tired again and it did in fact produce the shared library.
Sorry for the noise folks!
