I want to build an equimolar CoCrFeMnNi (20% at. each) in Lammps. I wrote the script for the tension test. However, when I wanted to visualize it with Ovito, I saw it explode. I tried other combinations, and it works. But it does not work for this specific ratio and keeps exploding. I would be so grateful if there could be a suggestion for that.
with regards,
here is the script:
# ------------ Initialization -------------
atom_style atomic
variable latparam equal 3.595
# ------------ Atom Definition ------------
lattice fcc ${latparam} orient x 1 0 0 orient y 0 1 0 orient z 0 0 1
region whole block 0 10 0 10 0 10
create_box 5 whole
mass 1 58.933195
mass 2 51.9961
mass 3 55.845
mass 4 54.938044
mass 5 58.6934
create_atoms 3 box
set type 3 type/fraction 1 0.2 12345
set type 3 type/fraction 2 0.25 54321
set type 3 type/fraction 4 0.33 11111
set type 3 type/fraction 5 0.5 22222
group g1 type 1
group g2 type 2
group g3 type 3
group g4 type 4
group g5 type 5
dump 1 all custom 100 md.dump id type x y z
minimize 1.0e-4 1.0e-6 100 1000
# ------------ Force Fields ---------------
pair_style meam
#pair_coeff * * library.meam Co Cr Fe Mn Ni test.meam.txt Co Cr Fe Mn Ni
pair_coeff * * library.meam Co Cr Fe Mn Ni CoCrFeMnNi.meam Co Cr Fe Mn Ni
# ------------ Equilibration --------------
#reset_timestep 0
timestep 0.001
delete_atoms overlap 0.3 all all
velocity all create 300 12345 mom yes rot no
#fix 1 all nve
fix 2 all npt temp 300 300 0.1 iso 0 0 1 drag 1
thermo 100
thermo_style custom step lx ly lz press pxx pyy pzz temp
run 4000
write_data equil300kalloy.data
unfix 2
variable tmp equal "lx"
variable L0 equal ${tmp}
variable L1 equal ly
variable L2 equal lz
# ------------ Deformation --------------
fix 2 all nvt temp 300 300 .1
variable srate equal 1.0e10
variable srate1 equal "v_srate / 1.0e12"
fix 3 all deform 1 x erate ${srate1} units box
variable strainx equal "(lx - v_L0)/v_L0"
variable strainy equal "(ly - v_L1)/v_L1"
variable strainz equal "(lz - v_L2)/v_L2"
variable p1 equal "v_strainx"
variable p2 equal "v_strainy"
variable p3 equal "v_strainz"
variable p4 equal "-pxx/10000"
variable p5 equal "-pyy/10000"
variable p6 equal "-pzz/10000"
fix def1 all print 100 "${p1} ${p2} ${p3} ${p4} ${p5} ${p6}" file CoCrFeMnNi_100.def1.txt screen no
thermo 100
thermo_style custom step v_strainx v_strainy v_strainz press temp v_p4 v_p5 v_p6
run 10000
print "All done"
